Old 03-10-2009, 01:31 PM   #451
l3asher's Avatar
Ha!
l3asher is offline   Reply With Quote
Old 03-10-2009, 01:35 PM   #452
desertbird's Avatar
Hobby shop or use this conversion to get something close:
http://bobmay.astronomy.net/misc/drillchart.htm
I believe this conversion chart also tells you the size of Losi piston holes, if you ever care to know....
Its a .052" bit
It's a little larger then 3/64ths (.052" X 64 = 3.328 64ths)
a #56 hole is just under 3/64ths (.0465" X 64 = 2.976 64ths)
desertbird is offline   Reply With Quote
Old 03-10-2009, 06:27 PM   #453
Tim Dougherty's Avatar
Originally Posted by Adam Drake View Post
Integra- The measurement should have always been 23.4, but it's not much of a difference. 23.3 or 23.4 and it's time to replace the clutch shoes.
David Wall- I ran my standard set-up from the Losi site. The changes I made: Center Smartdiff, with two .15 springs, M3 Holeshots with Losi molded inserts, and I ran a little more toe-out in the front.
party_wagon- I don't think the design of the 8ight driveshafts will have more wear then a CVD, but the reason for the design is because we wanted the longest possible bone and we wanted to capture the pins with the bearing.
ovalosi- I've only raced the L8ight once and I ran 15/48. What carb insert are you running? If you need more top-end I would go to a 8mm.
clebo3- The 8ight 2.0 is easier to drive and allows you to push the buggy more then the 8ight.
jeremy reed- Both should use a 23 horn.
bcquick- 7,000 in the front diff, 3,000 in the rear diff and I would go to silver rear springs, outside hole on the rear arm and run a 56 piston with three holes drilled out with a #55 drill bit and 25wt oil. Let me know how it works.
Adam in reference to David walls Psycho Nitro question, your answer a little more toe outwards is that 1 deg or 1/2 deg? Is that a good rule to use if a buggy has push and track might be a little loose?
Team Epic
Extech .21FM and .24FM
Team Losi
FASTLANE GRAPHIX - http://www.fastlane-graphix.com
Tim Dougherty is offline   Reply With Quote
Old 03-12-2009, 09:22 AM   #454
ovalosi's Avatar
Trader Rating: 55 (100%+)
Default ?
Does anyone know the next best option 2 a grp pipe on a tuned grp .21. I run dirt oval. thanks for any answers
ovalosi is offline   Reply With Quote
Old 03-12-2009, 09:31 AM   #455
Trader Rating: 163 (100%+)
what are you looking for? more top end or more low to mid grunt?
cjm1126 is offline   Reply With Quote
Old 03-12-2009, 10:04 AM   #456
j_castano's Avatar
Hello everybody.!
My name is Jose, Im from Ibiza, in Spain.
I have just buy a second hand losi eight 1.0 to start with this car.
My idea is to start with 1.0 try it for few racers and look how it works, and late buy the new 2.0.
I just wonder if is many differents in drive the 1.0 to the 2.0.
Thanks very much.
Jose Castaņo
Losi 8ight 2.0
Novarossi Plus4FT
Team Zona-RC
j_castano is offline   Reply With Quote
Old 03-12-2009, 10:13 AM   #457
Integra's Avatar
Originally Posted by j_castano View Post
Hello everybody.!
Thanks very much.
the 2.0's are alot different from the 1.0's.....My suggestion would be to start reading the 2.0 thread's....start with this one.
Old 03-12-2009, 11:28 AM   #458
ovalosi's Avatar
Default PIPE?
I have plenty of low end, need more top!
Old 03-12-2009, 11:48 AM   #459
Frank L's Avatar
Trader Rating: 148 (100%+)
Dynamite 086. Nova 9886. Thunder tiger 086. All will give execellent top end. Also the trinity bad boy pipe is a best all around. I am pleased with it so far on a grp tuned .21. Also try a dynamite 053 it's much more free than the grp pipe.
Old 03-12-2009, 11:50 AM   #460
the dynamite 086 will give you more top end, i ran it offroad and liked it but it seemed a little soft on the bottom. i do like the losi re10 or the dyn 053 better for offroad but i think the 086 would be great on an oval. the losi re11 might be a good choice also but i have not tried it.
Todd Green is offline   Reply With Quote
Old 03-12-2009, 11:50 AM   #461
i found the 9853/053 to be the best pipe on the engine, the 2053 was restrictive for me as well, also the ae/ttr 2035 was a really good choice for the engine
Old 03-16-2009, 09:34 AM   #462
Team Epic
Team Losi
Old 03-16-2009, 01:42 PM   #463
Adam Drake's Avatar
losi_racer- I use the bits from Racer's Edge.
Tim Dougherty- I don't have a gauge for the front toe, but I went to about 1 more degree of toe-out per side.
ovalosi- Losi RE10.
Adam Drake is offline   Reply With Quote
Old 03-18-2009, 04:41 PM   #464
ovalosi's Avatar
Default ?
Can anyone rate the losi 8 clutch springs from soft to hard for me? Thanks
Old 03-18-2009, 05:07 PM   #465
SupermaxxRich's Avatar
softest - black, green, gold, silver - hardest
Proudly Sponsored by:
-HB Racing-Pro Line Racing-OS Speed-MKS Servos-VP Race Fuel-Hobbywing-SANWA-J&T Bearings-Tony Screws
SupermaxxRich is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
