Old 03-08-2009, 10:10 AM   #436
ovalosi's Avatar
Trader Rating: 55 (100%+)
Thumbs up Hey Adam
I run a tuned grp .21 on a oval that has a 250 driveline and no shortage of traction.Can you suggest a gear change , I currently run the 14/48 that comes with the l8ight.It is not enough top end and I am spared for cash and can't afford more than 1 gear right now.Thanks for any suggestions.
ovalosi is offline   Reply With Quote
Old 03-08-2009, 12:15 PM   #437
losi_racer's Avatar
Trader Rating: 25 (100%+)
the 14/48 is a nice gearing, but if its still not enough go with 48/15. a 48/16 will work to but that will take a lot of the low end
this is how you do gearing
spur- higher number of teeth- faster accel/ lower number-faster top end
clutch bell- higher number- faster top end/ lower- faster accel
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 03-08-2009, 02:18 PM   #438
I currently have the losi 1.0 buggy and have been thinking of upgrading to the 2.0. I'm a decent sportsman class driver still learning. My question is will the 2.0 help me much or should I continue to learn with the 1.0?
clebo3 is offline   Reply With Quote
Old 03-08-2009, 02:26 PM   #439
jeremy reed's Avatar
Default servo insert
hey guys quick question ..i have 2 1.0 truggies,1 i race ,1 for back up.the one has z9100 series servos and seems to take 25 tooth horn insert and the other one has 9000 series servos and seems to take 23 tooth serv horn inserts..is this right??if so is there anywhere i can get just the inserts i need without buying the whole tree from losi
Team KAMIKAZE Racing
"DONT RUN,YOU'LL ONLY DIE TIRED"
PANCAR
jeremy reed is offline   Reply With Quote
Old 03-08-2009, 02:34 PM   #440
losi_racer's Avatar
the question is do you have the money. if so grab it. but i dont think it will help TONS but its def. better then the 1.0. i have both 2.0's and i love them over the 1.0 and i started racin in sept 08
both are the 23 tooth. the 25 is the wrong one. ALL jr is 23. and no you gotta buy the inserts as a set, its only 3.39.. i would just buy the alum servo horn for steering tho
Old 03-08-2009, 06:20 PM   #441
ok thanks.i would like to get the alum one for both trucks but im scared instead of the insert stripping ,if i use the alum one that it will blow my servo
PANCAR
Old 03-09-2009, 11:21 AM   #442
bcquick's Avatar
Adam.
2.0 buggy with your standard setup .
on extreamly high bite track ,what would you change to get rid of a bunch of steering,car is way way to twitchy.
bcquick is offline   Reply With Quote
Old 03-09-2009, 12:35 PM   #443
losi_racer's Avatar
i had the same worry as you. but as long as you have the servo saver set right you shouldnt have a problem. ive been running an alum horn since i got my truggy and i havent blown my steering servo.just make sure that servo saver spring isnt set to tight
Old 03-09-2009, 05:43 PM   #444
SHOULDNT IT BE SET OK WITH THE FACTORY SETTING?
PANCAR
Old 03-09-2009, 05:58 PM   #445
Integra's Avatar
cars are adjustable for a reason.
Old 03-09-2009, 07:33 PM   #446
losi_racer's Avatar
Old 03-10-2009, 11:38 AM   #447
Adam Drake's Avatar
Integra- The measurement should have always been 23.4, but it's not much of a difference. 23.3 or 23.4 and it's time to replace the clutch shoes.
David Wall- I ran my standard set-up from the Losi site. The changes I made: Center Smartdiff, with two .15 springs, M3 Holeshots with Losi molded inserts, and I ran a little more toe-out in the front.
party_wagon- I don't think the design of the 8ight driveshafts will have more wear then a CVD, but the reason for the design is because we wanted the longest possible bone and we wanted to capture the pins with the bearing.
ovalosi- I've only raced the L8ight once and I ran 15/48. What carb insert are you running? If you need more top-end I would go to a 8mm.
clebo3- The 8ight 2.0 is easier to drive and allows you to push the buggy more then the 8ight.
jeremy reed- Both should use a 23 horn.
bcquick- 7,000 in the front diff, 3,000 in the rear diff and I would go to silver rear springs, outside hole on the rear arm and run a 56 piston with three holes drilled out with a #55 drill bit and 25wt oil. Let me know how it works.
Adam Drake is offline   Reply With Quote
Old 03-10-2009, 01:11 PM   #448
losi_racer's Avatar
where do you find these drill bits? i looked at lowes and home depot
Old 03-10-2009, 01:29 PM   #449
Integra's Avatar
http://www.amainhobbies.com/product_...ducts_id/20261
Old 03-10-2009, 01:29 PM   #450
l3asher's Avatar
http://www.amainhobbies.com/product_...ducts_id/33800
l3asher is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
