Old 02-19-2009, 06:05 AM   #421
Integra's Avatar
Originally Posted by mackyrocks View Post
Hey Adam,
What is the minimum that the diameter of the clutch can get before the clutch shoes need to be replaced? I saw it somewhere on rctech but I can't find it now.
Thanks,
Zach
23.3 is the measurement.
Old 02-19-2009, 06:54 PM   #422
It is amazing, I never tought my original post for the 8ight in my manufacturers' corner will reach 15 pages !!!
#WeAreAE The Forum - RCTen.com
My R/C Blog - MyRCBox.com
Sylvain is offline   Reply With Quote
Old 02-23-2009, 08:14 AM   #423
Hi Adam...
Will the new flex chassis (2mm longer) fit the first version off the 8ight buggy? We need to upgrade anything?
triloya is offline   Reply With Quote
Old 02-25-2009, 09:21 PM   #424
ovalosi's Avatar
Trader Rating: 55 (100%+)
Thumbs up Lonely ovalosi
Hey Adam , have you had a chance to race a l8ight model yet?If so how was it?I sure love mine!
ovalosi is offline   Reply With Quote
Old 02-25-2009, 09:29 PM   #425
ovalosi's Avatar
Questions?? new grp
Hey Adam , should a new tuned motor need to be sealed up,or only if it has problems
Old 02-27-2009, 11:07 PM   #426
tharris1959's Avatar
Originally Posted by Integra View Post
i have the 1.0+2.0B and a 1.0T and am defiantly an A guy......the rear hub did not change enough to justify it being weaker or more prone to eating the bearing's.
The zero offset wheel places more stress on the shaft and bearing at the hubs...simple trigonometry. The outer bearing is small and cannot take as much stress as the larger bearings. Especially if you run neg camber.
I drilled out the outers for the larger bearing size, no problems. If you run a track with whoops and large jumps, the bearings were blowing in mine rather quickly. Now they are ok
This is a very good truggy, just a couple of band aids and it's rock solid
tharris1959 is offline   Reply With Quote
Old 02-27-2009, 11:10 PM   #427
Originally Posted by triloya View Post
Hi Adam...
Mine did
2mm= --
That's not much
Old 02-27-2009, 11:16 PM   #428
Matt Howard's Avatar
Hi Adam...
Originally Posted by tharris1959 View Post
Mine did
2mm= --
That's not much
it will fit but you'll need the center rear driveshaft from the 2.0, the 1.0 driveshaft will not reach the center diff since the chassis is longer
Official member of The Guild of Calamitous Intent and proud supporter of Conjectural Technologies.
Serpent S411 LE kit #192
RCTech #361
Matt Howard is offline   Reply With Quote
Old 03-02-2009, 04:46 PM   #429
Driveshaft part #A3536
There's a few other changes to the buggy, depends how much you want to do. Radio tray changed, center diff assy , front hub carriers, rear hubs, shock towers and the steering geometry.
If nothing else I would at least get the front hub carriers to go with that. It seems to give me a little more turn in
Old 03-03-2009, 11:27 AM   #430
Integra's Avatar
we were more so talking about the buggy 2.0..... the T 2.0 discussion is over in the T 2.0 thread.
Old 03-03-2009, 01:01 PM   #431
Adam Drake's Avatar
HAWK498- Yes, I will be at RCX.
dsl- I don't make the front window hole bigger on the 8ight T 2.0.
l3asher- Not sure, but I will look into it.
cjm1126- No, not when the shock is built and the caps is installed.
l3asher- Running silicone fluid in the Smart diff won't hurt anything, but it will make the bugy or truck difficult to drive. I only use the smartdiff grease.
cota348- I always use buggy gearing on the buggy. You will notice the biggest difference with the smart diff on low bite tracks.
LOSI MAD- We will look into it.
J-DUB- We have had some problems with the bearings that came in the hubs of the 8ight T 2.0, but the replacement Losi bearing are great. I think we just got a bad batch in the kits. We will fix the problem.
mackyrocks- 23.4mm
triloya- You will also need to change the center rear driveshaft.
ovalosi- Yes, I raced it at J Tec and had a blast. You don't need to seal the tuend engine unless you are having a tuning problem.
Adam Drake is offline   Reply With Quote
Old 03-03-2009, 02:11 PM   #432
Integra's Avatar
Originally Posted by Adam Drake View Post
mackyrocks- 23.4mm
I see your now up .1mm..... do you feel the .3 is going too far ?
Old 03-03-2009, 04:03 PM   #433
Thank you Integra
Old 03-03-2009, 07:21 PM   #434
David Wall's Avatar
Adam, could you share the setup you settled on at the Physco Nitro blast. My buggy worked good everywhere except shock therapy section, just want to find out where I went wrong.
David
Retired!
David Wall is offline   Reply With Quote
Old 03-03-2009, 09:38 PM   #435
Trader Rating: 26 (96%+)
I was curious as to why losi doesn't use flex cables or true cvds in the drive line for this buggy. The design of the driveline is going to cause increases and decreases in velocity of the spinning parts which will cause more wear.
party_wagon is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
