Old 01-24-2009, 11:51 AM   #361
Frank L's Avatar
Trader Rating: 148 (100%+)
Originally Posted by ABURTON View Post
Some shops have a pretty low special price through coupons or monthly specials, if you paid a low price like $564 because you had a store coupon then I bet you don't get the wheels, if you walked in a store and paid $650 you probably get them.
Joey Powell, thanks man! See ya at the Battle this year!
$86.00 bucks for wheels. Those must be some damm nice wheels.
Old 01-25-2009, 12:13 PM   #362
nccattu's Avatar
Adam do you guys ever use set up stations? If not how is it that you guys set your toe, I saw your videos on camber and ride height just not on toe. Thanks
nccattu is offline   Reply With Quote
Old 01-26-2009, 11:32 PM   #363
teeforb's Avatar
Trader Rating: 94 (100%+)
Send a message via Yahoo to teeforb
Hey Adam,
Question about the 8T 2.0.
1) is it the same front/rear tranny as the 1.0?
2) if the answer to question 1 is yes, why a 50T spur?
3) I am going straight electric. what spur/pinion size do you recommend to start with?
thx!!!
=teeforb
$$ Team High Budget $$
17.5 stock buggy fb page
https://www.facebook.com/groups/17.5stockbuggy/
teeforb is offline   Reply With Quote
Old 01-27-2009, 12:08 AM   #364
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by teeforb View Post
Hey Adam,
thx!!!
=teeforb
there are no transmissions in the losi 8ight, they have differentials. Two different things
Byron Fuels/AKA Tires/Radiopost/TKO/Viper Rc/Dialed Inc/Empire Metal Product/Advantage Racing Products
losi_racer is offline   Reply With Quote
Old 01-27-2009, 12:13 AM   #365
teeforb's Avatar
okay, differentials ratio.... i jus used tranny as figure of speech....
Old 01-27-2009, 04:28 AM   #366
l3asher's Avatar
Hey Adam,
thx!!!
=teeforb
1) The answer is yes they are the same, I just compared the part numbers to each other.
l3asher is offline   Reply With Quote
Old 01-27-2009, 07:50 AM   #367
JAMMINKRAZY's Avatar
Trader Rating: 17 (100%+)
Hey Adam,
thx!!!
=teeforb
Yes the ratios are the same. the reason for the 50t spur is to give more bottom end without sacrificing very much top end. Alot of people ran/run the 50t on thier 1.0's.
-Koby Kubrin-
Thanks to my Sponsors:
Serpent America | Team Novarossi | Desoto Racing | Race AKA | Ridgeway Bodies
JAMMINKRAZY is offline   Reply With Quote
Old 01-27-2009, 08:17 AM   #368
Eccentric's Avatar
+1
The current 'trend' with the new truggies it to have numericaly higher Final Drive Ratios (FDRs). The X1CRT had an FDR of 15.78/1. Other 'older generation' truggies are similar. The MBX5T was one of the first to go over 16/1 with an FDR of 16.28/1, as was the Kyosho STR (and later the STR-R) with a16.54/1 FDR. The V1 8igh-T was at 15.87/1. The RC8T has an FDR of 16.59/1 (using a larger 54T spur and a 14T bell for some reason). The X2CRT has a 16.61/1 FDR.
The 8ight-T V2.0 has an FDR of 16.54/1, which is the same as the K-Cars (using the same 13/50/4.3 bell/spur/diff combination). Losi's just following the trend. The 16.3-16.6/1 FDRs tend to work better with high revving .21s. For the few guys left running .28s, running the 48T spur for a 15.87/1 FDR (or the Robinson Racing 49T spur for an FDR of 16.20/1) on the 8ight-T would probably make more sense.
Just experiment if you're bored. Pick up an extra center diff or two offa fleabay and set it up with different spurs (47/48/49/50 are available specificaly for Losi, and 51/52/53/54 are available for HPI diffs). Try them with 13T, 14T, and 15T bells.
-Aaron
Dangit, when did all my favorite cars, trucks, airplanes, and engines become "vintage"???
Eccentric is offline   Reply With Quote
Old 01-27-2009, 08:45 AM   #369
teeforb's Avatar
im going electric with my 2.0T. should i use the 50T spur or what?
Old 01-27-2009, 09:24 AM   #370
Eccentric's Avatar
Your motor manufacturer should have a chart with recomended Final Drive Ratios. The 8T has a 4.3/1 ring/pinion ratio. Take the motor manufacturer's recomended FDR and divide it by 4.3. Multiply the number you get by the pinion tooth count you're gonna use. That will give you a number that should be close to the spur gear you need.
Alternatively, if you settle on a spur gear (lets use 50T, since the truck comes with it) then divide your target FDR by 4.3. Divide 50 (spur tooth count) by the number you just came up with to get the approximate pinion gear you'll need.
-Aaron
Old 01-27-2009, 05:05 PM   #371
Adam Drake's Avatar
Integra- The problem could be the P3 plug is too hot. Try a GRP 5 or P4. OS plugs will work fine in a GRP, but a P3 is too hot.
l3asher- The parts will work on the 8ight T 2.0. Not sure about the wheel deal.
nccattu- I don't use a set-up station. I just roll the car or truck up to a wall and use a camber gauge on the wall to measure toe.
teeforb- Same internal ratio, but the 50 tooth spur is what most of us used on the old truck. Not sure about gearing for an electric 8ight T, but email me and I will findout for you. adrake@horizonhobby.com
Adam Drake is offline   Reply With Quote
Old 01-27-2009, 06:13 PM   #372
Default How easy to drive?
HI Adam
When you said "The 8ight 2.0 is much easier to drive, better on rough tracks and lighter."...could you tell us what's the new improvements that make the new version much easier to drive and how much lighter the 2.0 is?
Thanks and good look in the Nitroblast 2...we want to see the 2.0 flying over 150ft...
triloya is offline   Reply With Quote
Old 01-28-2009, 08:31 AM   #373
l3asher's Avatar
Adam, does the 8T 2.0 body protect the cooling head any, like the old 1.0 does?
Old 01-28-2009, 08:42 AM   #374
teeforb's Avatar
is the 8T 2.0 body comes pre-cut or no?
Old 01-28-2009, 10:50 AM   #375
I guarentee that the one that comes with the roller will be precut. As far as the ones sold seperately I am betting they will be cut aswell but not certain.
-Koby Kubrin-
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
