Adam Drake talks about the new 8ight 2.0
#331
#332
#334
HiVoltg12- I clean my car by removing the engine and radio tray. Then hoseing it off with Simple Green and water. Just make sure you blow it off very good after cleaning. I don't use WD40 because it makes the car look good, but attracts more dust the next time you are at the track. Then just put a drop of bearing in the CV joints.
givemeshine- What's the actual problem you are having? The GRP engine should fit in the 8ight with no problems.
tharris1959- The castor block have an option hole and have more steering throw.
ABURTON- Great job Alan!
bustedpiecesrc- Yes, you want to point the tempgun at the plug.
Chris__RC- I run two alum with gold springs and two plastic with green springs. If you are looking to get longer shoe life run green and black springs.
jbergman- You may have a set of turnbuckles that are a little undersized. Please give Bill Goldsmith a call in customer service and he can get you a new set. Bill's ext. is 300.
#336
#337
hey adam...
i have a grp in my losi 2.0. i started tuning it. and its doing great but its still rich in the high end. but if i lean my hsn anymore it cuts, if i lean the lsn its cuts out.
i know you tune with the lsn on this engine so i have done that. my hsn is maybe 1/4 leaner then stock,
#338
l3asher- Feel free to ask any questions about the 8ight T 2.0 here.
losi_racer- How much fuel have you run through the engine? Sounds like you are trying to get too much out of the engine to soon. What pipe, plug, fuel, ect...
#339
yea i thought about that after i sent that, its a new engine, i broke it in and MAYBE 3 tanks after that. so i richened it up and leavin it till i get more fuel thru it. it still screams now tho. my first race on the 2.0 and the grp will be tommrow
but btw im usin a p3 plug, 053 pipe, and sidewinder fuel
#340
Adam what do you think of the new 8-t 2.0? Is the handling of the truck a big improvement?
#341
OS plug in a GRP ? thats a big no no imo.
#343
#345
believe me, the OS plugs work PERFECTLY in a GRP! I run them exclusively as I feel the engine makes more bottom end with a OS P4 plug plus it idles slightly better. ALLOT of the Team Losi guys run OS plugs as well.
No issues with sealing or anything else.
