Old 11-24-2008, 12:51 AM   #256
Tin
Originally Posted by Integra View Post
little mod i did to my 1.0 chassy's
what is this mod you did to your chassis and whats the benefit to it?
Kyosho Inferno MP9
GRP .21 Tuned TURBO
Futaba 4PK
Tin is offline   Reply With Quote
Old 11-24-2008, 05:44 AM   #257
Trader Rating: 24 (100%+)
He did the same upgrade that the new 2.0 has on it. THis has a small counter sunk screw that creates the "contact" patch for your droop screws. This keeps from having steel on aluminum wear and ever changing ride height.
This way things stay the same as the steel/steel will nearly not wear.
ABURTON is offline   Reply With Quote
Old 11-24-2008, 06:27 AM   #258
Integra's Avatar
the Constant Droop adjusting was the thing that got me.......soo much to a point that I NEVER set my droop...some may call me crazy....but w/e it's worked for me....i Do realize what set-up wise what im missing as ive driven buddy's cars with droop all set so they say.......so im very excited to actually run some darn droop on my cars now.
Old 11-24-2008, 07:50 AM   #259
Integra, what did you use to get the countersink in the chassis correct?
clebo3 is offline   Reply With Quote
Old 11-24-2008, 08:01 AM   #260
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Counter sink drill bit .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 11-24-2008, 09:49 AM   #261
Integra's Avatar
Bri.
from the tool and die shop i buy my bits from the guy explained that most of my hardware (rc grade stuff) has the same countersink angle's....therefor a standard countersink bit would work just fine....BUT i will warn you...if you cheep out on a crappy bit...its gonna give you a crappy counter....i would recommend spending at least 15-20$ on a decent bit....also you'll need a 1/16 and 3/32 QUALITY bits to do the job....along with a punch or scratch all or something to mark Dead center.
Old 11-25-2008, 12:59 AM   #262
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
i did this steel bump stop conversion to my chassis ages ago but i used a button head screw instead.
this is the part i used
http://www.amainhobbies.com/product_...ducts_id/15267
i found it was easier to get them out once they are worn down.
its way to hard getting the counter sunk screw out
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 11-25-2008, 01:21 AM   #263
TIX
TIX's Avatar
heres a pic of how i did it
Alan Nankervis.
Old 11-25-2008, 07:20 AM   #264
Bri.
You can use 3/8" x 82* three flute countersink. Perfect for making 4-40 to 8-32 standard countersunk holes. Then you can pick up a 4-40 tap from Sears or somewhere like that, and a punch. That should do the trick.
LosiMadMan is offline   Reply With Quote
Old 11-25-2008, 08:08 AM   #265
Adam Drake's Avatar
DirtyDezPirate- What clutch set-up are you running? Try richening the hsn even more. When are you going to Rev next?
losi_racer- I don't get out to The Nitro Pit that often. It's a five hour drive. What engine are you running? Try the following clutch set-up. 13/48, make sure you sand the inside of the clutch bell and spray all the oil / grease out of the bearings. I use Losi bearings and the following clutch set-up: two plastic shoes with green springs and two alum shoes with gold springs.
Adam Drake is offline   Reply With Quote
Old 11-25-2008, 08:12 AM   #266
Trader Rating: 66 (99%+)
Sorry to intrude on the 2.0 thread dudes. Adam, if you have time bro, can you chime in on the Losi 8ight build and setup thread as well? THAT WOULD ROCK!! cheers! TW
pwnzor is offline   Reply With Quote
Old 11-25-2008, 05:28 PM   #267
DirtyDezPirate's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to DirtyDezPirate
Adam, I am using same clutch setup that you have been running, green on compose, silver on aluminum.. UHmm.. next time i be at revo, not sure?? only time i can is on weekends.. whens the next event at revo?
I am just ME!
DirtyDezPirate is offline   Reply With Quote
Old 11-25-2008, 08:10 PM   #268
Integra's Avatar
hes running Gold on alum.
Old 11-26-2008, 07:24 AM   #269
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Adam, What is the easiest way to get the carb out of the motor. I want to clean my GRP .21, but i cant get the carb out. Even when i remove the screw and 2 pieces that hold it.
Bigedmond is offline   Reply With Quote
Old 11-27-2008, 10:19 PM   #270
Just bought a roller yesterday, honestly if it was a kit I probably wouldn't have got it because I just built a MBX6 and I just didn't feel like building another back to back. Anyway, my track is tight, smooth clay with med to high bite and large jumps. Using the stock setup as a baseline can anyone ( or Adam if you have time) suggest what changes might make it better for this type track? thanks
KyJoe340 is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
