Old 11-04-2008, 05:19 PM   #166
jwcobra03's Avatar
Trader Rating: 69 (100%+)
What can i do about my front brakes sticking on my 2.0 after applying them? I have tried loosening the pads and adjusting the linkage.
jwcobra03 is offline   Reply With Quote
Old 11-04-2008, 10:39 PM   #167
jwcobra, make sure that the brake disk slide fairly easily onto the outdrive. If it is tight when you apply the brake the disk will cock slightly. If it is sticking on the outdrive it will not release right away and cause the feeling you are getting. Also make sure you do not have to much of a gap in your calipers or this will cause it also. I think the manual says somewhere around .5 mm. I hope this helps
Kevin Wilson is offline   Reply With Quote
Old 11-04-2008, 10:58 PM   #168
cornerspeed's Avatar
You may need to back off your front brake linkage some. With your radio tray set-up, how much throw to brake side does it take to engage. If it is very little, then that may be your problem other then the previous post.
Donny Vinkemulder
TLR Driver
TLR 8ight 3.0 - NovarossiUSA - Spektrum DX3R Pro - Losi Nitrotane VP 30% - Losi Lipo Batteries - Proline Tires - DE Racing - EKD Paint
--- Special thanks to: Dyno, Adam, Todd, and Kevin. Horizon Hobby
cornerspeed is offline   Reply With Quote
Old 11-05-2008, 12:38 AM   #169
nobike's Avatar
Trader Rating: 147 (100%+)
Originally Posted by Jimmy Pierce View Post
Went to revs on sunday evening and helped Dana,was going to run on tuesday but worked to long to make it out,to be honest, Dana built the track, i just helped for a couple hours,im sure its fun,headed to the track now off work early will tell Dana to post new pics asap!What happens in Vegas stays in Vegas!Have a good day!
Thanks for letting me drive your 2.0 jimmy P. its dialed, i want one now........
nobike is offline   Reply With Quote
Old 11-05-2008, 11:38 AM   #170
Adam Drake's Avatar
jwcobra03- Also try loosening the screws that hold down the top of the center diff mount.
Adam Drake is offline   Reply With Quote
Old 11-05-2008, 12:57 PM   #171
Integra's Avatar
TOUCHE Mr drake.....on my truggy center diff i had that problem...if the front tank side screw was too tight the brake cam would bind up real bad.
Old 11-05-2008, 04:21 PM   #172
jwcobra03's Avatar
Thanks fellas i will give those suggestions a shot!
Old 11-06-2008, 01:48 AM   #173
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
Hey Adam,
Do you still need to use the 2 o-rings under the Battery box.
It doesnt say in the manual and i know its a new radio tray
but i dont want to blow up a servo
Tix
TIX is offline   Reply With Quote
Old 11-06-2008, 11:58 PM   #174
DirtyDezPirate's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to DirtyDezPirate
Originally Posted by Bigedmond View Post
Are you thinking it a little fat because it is bogging as you apply throttle??
BTW, a racer here had his GRP .21 temp at 403. We immediately richened the top 1 full turn, and then shut it down. Put the piston at bdc, then set the car near a fan to cool it off slowly. This weekend, the same motor ran great, and still had pinch. Either way, he just ordered new bearings.
no bogging, it just is cold at first for a few mintues to like 3/4 of tank then it starts to get hot and lots of power.
I am just ME!
DirtyDezPirate is offline   Reply With Quote
Old 11-07-2008, 07:18 AM   #175
Bigedmond's Avatar
Trader Rating: 18 (100%+)
I had the same issue. I richened the top 2 hours and bottom 1 hour, and my temps came down to 190, and the bog was gone.
The GRP to me seems to lean bog a little easier then rich bog.
Bigedmond is offline   Reply With Quote
Old 11-07-2008, 08:38 AM   #176
Trader Rating: 52 (98%+)
Default grp problem
+1 bigedmound. ran grp all this yer put 8 gallons on it. top is to lean and bottom is to lean. i would richen bottom like 3-4 hours and top same way. only lean top so that it clears out down the staight. use bottom end for tunning. start tuning from bottom and temps will drop. also run grp num4 plugs helps alot. jp3 or msr 1009 pipe make motor come alive and cool temps down
mixedguy is offline   Reply With Quote
Old 11-10-2008, 08:57 PM   #177
bustedpiecesrc's Avatar
Trader Rating: 51 (100%+)
Send a message via Yahoo to bustedpiecesrc
Hey Adam, i need a little help with tuning my motor, i get about 7 min of run time and the temp is up there a piece or two at 260, it has the 8mm restrictor in it and a mcCoy 8 plug in it, how do you tune the motor or what do i need to change to get 10 min of run time and get the temp down? Thanks
bustedpiecesrc is offline   Reply With Quote
Old 11-11-2008, 11:27 AM   #178
Trader Rating: 36 (100%+)
Any chance (sorry if this has been ask/answered, I'm not about to read the entire thread) of a 2.0 kit? Sorry (again :P ) if I'm perceived as being an @#$hole, but I won't even consider a roller. Thx
NitroOB4You is offline   Reply With Quote
Old 11-11-2008, 12:48 PM   #179
Integra's Avatar
No kit.........buy the roller...its worth every penny imo.
Old 11-11-2008, 05:01 PM   #180
Yep I agree also....Finally got a chance to run mine this weekend and love the handling...definitely worth every penny.
Collection:Kyosho Turbo Scorpion, Losi 8ight-T race roller, Losi 22-4, Traxxas Slash 4x4 (speedrunner), HPI R40, HPI RS4 3 Evo, HPI RS4, Losi Mini-T, Mugen MRX-3, HPI RS4 Mini Electric, HPI RS4 Mini nitro
DaveNJ80 is offline   Reply With Quote
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
The Nitro Pit Dbackmasta Arizona-New Mexico Racing 18732 09-13-2012 08:27 AM
