Old 09-30-2008, 11:57 AM   #1
t0adman's Avatar
Default OS V-Spec Rebuild - Part Dos
Some of you may recall a post from me a while back about how my first gen V-Spec started flaming out and sounding terrible. I took it apart, baked it in the oven, removed and replaced the front and rear bearings, replaced the con-rod, and put it all back together...correctly I think.
FF to last Saturday. I was at the track and decided I would try to get the thing running. I got it fired up but could only keep it running when it was around 1/3 throttle and that was idle RPMs. I took off the air filter to see what was going on with the car and it was spitting fuel out and all over the buggy. Not a ton but I don't except to see any fuel coming OUT of the carb intake. I put all the needles at factory settings then cranked them down a little so it wouldn't be super rich. I can get it started and it will rev up well but it's rich and won't idle normally.
What do you think is going on? In what order should I start checking things and troubleshooting?
t0adman is offline   Reply With Quote
Old 09-30-2008, 01:15 PM   #2
AssocRacer's Avatar
Send a message via AIM to AssocRacer Send a message via Yahoo to AssocRacer
It's spitting fuel OUT OF the carb?
Lots O' Planes
AssocRacer is offline   Reply With Quote
Old 09-30-2008, 01:26 PM   #3
mugenb46's Avatar
normally a v spec will spit fuel out the carb when it's very fat, this accures alot during breakin, and is a good sign that it has plenty of fuel running through it.
Check the plug, or did you change to a cooler plug, and are the correct shims installed in the head button.
When you where trying to get it to tune right before it may have put your settings way off.
Also, did you change pipes, this will change the tune also.
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 09-30-2008, 02:06 PM   #4
A buddy of mine had a very similar sounding issue last week. It turned out that he had reinstalled the piston backwards. It would run if the throttle was held open some but did not idle at all. Remember that the skirt of the piston should be towards the back plate.
If this is the case just be glad it is an OS, becuse many other engines would have broke the piston skirt off.
Justin Watson
you can't beat a LOSI
Team LOSI Racing
Airtronics
Fusion Motorsports
Jwatson is offline   Reply With Quote
Old 09-30-2008, 02:43 PM   #5
t0adman's Avatar
Thanks for the good feedback guys. I'll go home tonight and make sure I have the damn piston in correctly.
Old 09-30-2008, 05:38 PM   #6
mugenb46's Avatar
also for safe measure, be sure the rod is installed right, both sides look the same, but look at the bottom bushing, the side with the chamfered edge, goes in facing the crank. Good luck.
And, yes the motor will run with the piston in backwards, and dies at low RPM because once the boost side of the piston clears the exaust, all case preasure esscapes.
Brian Carey
Pro Twister Mods
615-838-5373
Old 09-30-2008, 09:26 PM   #7
rcdaddy's Avatar
Definitly the piston is in backwards. Lets just say that is for sure what it is. Lets not talk about how I know for sure that is the problem.
I done the same thing. Surprizingly the motor will run, it just wont idle.
Drive It Hard and it Will Be Fast
Nova Rossi, Jammin, Team Associated, OS Engines, Futaba, Airtronics, Go Engines, RB Mods, Fusion Motorsports
WCRC Raceway
Big Billy's RC World
Baity's RC
rcdaddy is offline   Reply With Quote
Old 10-01-2008, 02:05 PM   #8
sickjamminracer's Avatar
Trader Rating: 23 (100%+)
if its not that then try a different glow plug
www.myspace.com/krystallinemusic
W.P.A.C crawlers
The Raceway
sickjamminracer is offline   Reply With Quote
Hpi Pro 4 Barry White Electric On-Road 16052 08-08-2017 02:05 PM
2006 Reedy Touring Car Race of Champions MikeR Racing Forum 230 05-30-2006 08:39 PM
FW-05 Parts windix60 R/C Items: For Sale/Trade 5 10-06-2004 06:59 AM
MARCCA Sedan Novak Spec class GordonFreeman MARCCA Discussion 32 03-23-2004 10:57 PM
tons of used tc3 parts all mint shape updated list more added today jan 25th jason cheng R/C Items: For Sale/Trade 0 01-25-2004 04:08 PM
