Old 09-28-2008, 09:24 AM   #1
Cannondale1974's Avatar
Trader Rating: 29 (100%+)
Default MBX5R suspension binding up w/application of O'lube
I bought a practically brand new 5R recently and raced it for the first time over the weekend, conditions were VERY DUSTY. My routine is to airhose the car and liberally apply O'lube to all hinge pins and basically anything that moves after a few qualifers. I've done this in the past on my 8ight with no problems. My 5R's suspension now squeaks like crazy and wont rebound properly. I'm guessing dust has worked it's way into the hinge pins causing binding. Has this been anyone's experience? Should I simply refrain from lubing the car during racing? (O'lube dries after a few minutes also)
One last question: Should the stock 5R's shocks be built with full rebound? Mine have little rebound at all and I built the 8ights with full rebound.
Thank you for your advice.
Cannondale1974 is offline   Reply With Quote
Old 09-28-2008, 09:34 AM   #2
Integra's Avatar
u dont use OD lube on the hingepins....only the CV's....and IMO that stuff dosent work too well...its a Wax based lube that is Guarenteed to attract Some dirt.....I would look into some sort of Dry Film lube...it can be had at most automotive stores and is relatively cheep....its an Aerosol too btw so application is alot easier.
Old 09-28-2008, 09:38 AM   #3
lorinser999's Avatar
Dirt and grits got inside,check some
lorinser999 is offline   Reply With Quote
Old 09-28-2008, 09:39 AM   #4
Trader Rating: 96 (100%+)
Dirt will work it's way into the hinge pins causing the bind. Also, make sure the threaded hinge pins are too tight. I tightened mine down and backed off 1/2 turn just to make sure.
Shock shafts aren't bent?
Pivot balls aren't bent?
Lastly, check the hinge pins for straightness.
K.Copeland is offline   Reply With Quote
Old 09-28-2008, 09:52 AM   #5
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i always use an aerosol silicone spray.. always had good luck and no noise!
jamminnay is offline   Reply With Quote
Cebu RC Car Racing Club jpn Manila Racers 14147 05-27-2016 09:01 PM
Batam RC Kopitiam batamrc Indonesia Racing 3502 07-28-2015 12:14 AM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
SUSPENSION 101 Losi Motor Man Rookie Zone 1 04-17-2007 06:40 AM
Tamiya lightweight suspension - trade for 415 suspension letitroll R/C Items: For Sale/Trade 3 10-19-2004 09:45 PM
