Old 09-23-2008, 05:20 PM   #1
blazinb's Avatar
Default drag brake?
just curious if anyone is using it with nitro vehicles, and some feedback
blazinb is offline   Reply With Quote
Old 09-23-2008, 05:23 PM   #2
Fear's Avatar
Send a message via AIM to Fear
No, I personally do not like the feel of a drag brake on an off-road car. On the other hand, I run a 15% drag on my touring car. Apples and oranges, though.
Robitronic Avid
MambaMax 7700kV, LiPo, JR Z9100S
Associated RC8
RB S7, JR Z9100S/Z9100T(nuked, at JR for repair)/Futaba BLS-351
Futaba 4PK
Fear is offline   Reply With Quote
Old 09-23-2008, 05:30 PM   #3
boostfiend's Avatar
Almost every pro and semi-pro racer I've seen uses drag brake, but I have yet to try it. I would think it'd take a little 'adjustment' away from jumping.
Hopefully someone that uses it will chime in.
boostfiend is offline   Reply With Quote
Old 09-23-2008, 05:31 PM   #4
dead1dave's Avatar
If you are just learning to drive it could put a bandaid on some of your short comings .
However I think learning to drive without it and using the brake as needed will make you much better in the long run .
For me ......I go out every week and try to drive better ..............but I think "throttle/brake control is harder to get the hang of than steering .
If you let off the throttle in the middle of a jump with drag brake .....your car is going to nose drive ...........that is going to be annoying .............especially when you don't want it to do that .
dead1dave is offline   Reply With Quote
Old 09-23-2008, 05:34 PM   #5
Trader Rating: 95 (99%+)
I use just a touch of drag brake on my 1/10th gas, none on my 1/8th buggy, and a lil bit on my 1/8th truggy.
I am using it on the 2 vehicles to help with turn in and to keep me from having to apply brakes and possibly apply to much brake. It is especially helpful to me on the 1/10th truck.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 09-23-2008, 09:11 PM   #6
stump27's Avatar
i tried it once, but i kept having the feeling something was binding.... like a bearing or something. it did help to keep the nose down on some of the jumps that i tended to jump nose up. it also seemed to turn in a little better, but i couldn't shake the sensation of something being wrong, so i just went back to tapping the brakes when i needed and took all the drag out that i could.
stump27 is offline   Reply With Quote
Old 09-24-2008, 03:57 AM   #7
MBR52's Avatar
Trader Rating: 8 (91%+)
Send a message via MSN to MBR52 Send a message via Yahoo to MBR52
Yeah, it can be a hassle when you have drag brake and u don't have smooth throttle control.
At the moment, I have just taken all drag brake out of my eight, as I found it to be a real pain in the but. I tried it after a fellow racer suggested that I try it. I found that it also takes some throttle extension away from me, so I wasn't quite gettin full throttle
Michael Brown
Associated RC8B powered by OS Speed
Associated RC8T powered by OS Speed
Mugen MST-1 powered by Novarossi
Associated B44 powered by Novak
MBR52 is offline   Reply With Quote
Old 09-24-2008, 05:19 AM   #8
tdeal823's Avatar
Trader Rating: 30 (100%+)
The full throttle is all in your radio. Get familiar with what all the adjustments do. Without looking at your radio and car. I would say you were moving the Trim, vs moving the sub trim. either way your problem could have been solved by the end point adjustments or persentage of travel(EPA)
Just an FYI
tdeal823 is offline   Reply With Quote
Old 09-24-2008, 05:36 AM   #9
lowey79's Avatar
i thought that drag brake was added by tightening the brake linkages rather than adjusting with your radio? Or can you use dead band adj. to get throttle response back?
lowey79 is offline   Reply With Quote
Old 09-24-2008, 09:55 AM   #10
JayL's Avatar
So you are moving neutral so the brakes don't drag on-throttle?
JayL is offline   Reply With Quote
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
U.S. Vintage Trans-Am Racing squarehead Electric On-Road 14187 03-21-2012 01:43 PM
E Crawler catkchun Malaysian R/C Racers 1152 05-02-2011 08:58 PM
Brushless Modified Cogging/Drag Brake Effect per different brands... StickyFingaz Electric On-Road 8 04-10-2008 07:07 PM
Top Driving Styles: Using Brakes and Drag Brakes SlamMan Electric On-Road 32 04-30-2007 10:11 PM
Tekin stulec52 Electric On-Road 443 01-17-2006 06:06 AM
