Old 09-23-2008, 05:03 PM   #1
Default Piston/ sleeve renewing
Has anybody used this service for their engines??
http://www.osrocketracing.com/pistonsleeve.php
They came highly recommended by a local racer.
Raddman is offline   Reply With Quote
Old 09-23-2008, 05:15 PM   #2
t0adman's Avatar
I've yet to have a sleeve pinched but I've heard OS Rocket and RayARacing are both good options. I've read that OS Rocket has "over pinched" some people's sleeves. I'm guessing they would fix it if that were the case. It seems like a good way to get more life out of sleeve though.
t0adman is offline   Reply With Quote
Old 09-23-2008, 05:38 PM   #3
Trader Rating: 95 (99%+)
I've used their services on several engines over the years. It's a great way to extend motor life. Just make sure you heed the instructions and richen it up to break it in again as described.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 09-23-2008, 05:42 PM   #4
K_B
K_B's Avatar
Trader Rating: 69 (100%+)
How much life can ya get from a re-pinch? I imagine results are all across the board...
K_B is offline   Reply With Quote
Old 09-23-2008, 05:44 PM   #5
22Racer's Avatar
Trader Rating: 67 (100%+)
If you keep the sleeve round when you pinch it you don't need to pinch it as tight as it came new. My break in on the sleeves I pinch is run it run 2 tanks 2hours richer on the track and let her eat. Some have gotten 8 gallons on a pinch.
Rex
Rw modding and engine repair http://www.rw-mods.com
Sleeve resizing $15.00/ motor rebuild $30.00
Argus engine distributor/Avid bearings/ Alpha engines/
Fx Royal engines/ Maxy Engines
e-mail rwmods@yahoo.com Rex Welch
22Racer is offline   Reply With Quote
Old 09-23-2008, 05:58 PM   #6
try rayaracing.com . ray does resizing for top racers around the world . great customer service and sets are generally back in 10 days at the latest.
bellinger is offline   Reply With Quote
Old 09-23-2008, 08:38 PM   #7
Allumina's Avatar
Trader Rating: 27 (100%+)
Send a message via AIM to Allumina
good thread, thanks for poisting it, i've always wanted to know exactly how pinching works, now I know. Thanks to everyone who replied too.
Allumina is offline   Reply With Quote
Old 09-24-2008, 09:50 AM   #8
JGray's Avatar
Get hold of Rick Brake at RBMODS.net. He does great work with quick turn times. He has done mine for the past three years with no problems at all.
JGray is offline   Reply With Quote
Old 09-24-2008, 10:03 AM   #9
Trader Rating: 52 (100%+)
osrocket hands down is awesome.
I am not bashing the other companies I jsut ahve not used them due to the fact that I didnt need to.
I send a piston and sleeve to osrocket and they have it back by the weekend.
one thing I do is order a new rod and after break in replace the old one and it is litterally a brand new motor (if not a little better) total ends up costing about 65 bucks after the rod but its literally a brand new motor for that.
I really havent met anyone that didnt approve of his work.
hope this helps
thanks
MO
Mo Denton is offline   Reply With Quote
Old 09-24-2008, 06:46 PM   #10
Trader Rating: 14 (100%+)
how many times can you resize a piston and sleeve.
meno222 is offline   Reply With Quote
Old 09-24-2008, 07:00 PM   #11
22Racer's Avatar
Atleast 3 times, depending on how much it is pinched each time.
Rex
Old 09-24-2008, 07:31 PM   #12
This will vary based on the sleeve wall thickness and sleeve material.
The more it is done 2 things happen. The metal gets more pliable and because the diameter is now a little smaller the sleeve will fit in the block just a tad looser. With each pinch it also gets just a tad looser each time. Since the sleeve is now looser it gives the piston the opportunity to "spread" the sleeve back out. This could cause your pinched sleeve to loose compression early if the sleeve material is week. That being said I'd think any decent engine could get pinched 2-3 times with no issues at all.
Old 03-29-2009, 09:37 PM   #13
Location: 4373 Creek Road Chaffee,NY 14030 USA (716)783-5198
Trader Rating: 23 (100%+)
Default RayAracing reconditioning-resizing service
Thanks for the kind words Brian,
I keep an eye on all forums resizing threads, just as you know I keep a keen eye on my work performance on the track.
See you at the new Gleenwood offroad track location in May.
RayA
RayA is offline   Reply With Quote
Old 03-29-2009, 10:23 PM   #14
houston's Avatar
Trader Rating: 91 (100%+)
if you resize you need to use ray , he invented it and perfected it
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 03-29-2009, 11:41 PM   #15
markt311's Avatar
Trader Rating: 32 (100%+)
I just got a used Vspec that was pinched, I broke it in with a heat cycle method for 6 heat cycles. Now it feels like it doesn't have much compression when it's hot but when you turn it over by hand you can feel almost like a "notch" feeling when the piston goes to TDC so I know the pinch is still tight. I haven't been able to run it much because of the weather but it does seem to want to run a little hot, around 240-250. Does anyone have any ideas on whats going on? I might have it just a bit lean on the top end. First race next weekend so I guess I'll see how she does.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
sleeve pinching? scurran Onroad Nitro Engine Zone 43 08-30-2010 05:00 AM
discussing only piston/sleeve resizing osrocket Nitro On-Road 45 05-13-2007 03:53 PM
osrockets piston/sleeve renewing osrocket Electric Off-Road 7 07-12-2002 09:06 PM
osrockets piston/sleeve renewing osrocket Nitro On-Road 10 05-09-2002 06:49 PM
