Old 09-23-2008, 05:16 AM   #1
TTR:EB4's Avatar
Default bad things about having no servo-saver
i have a caster racing K8T i took the servo saver spring out and put a piece of rubber there, now it turns wicked! but i have no servo saver, could the servo cop a couple of rolls? i dont usally slam into anything. most of the time :P
Mike
The Masher! >.<
TTR:EB4 is offline   Reply With Quote
Old 09-23-2008, 05:28 AM   #2
julius_makewar's Avatar
Mike, A servo saver is not there just to protect from an accident. It protects from jolts during cornering and from landings. If you dont run a servo saver you will always run the risk of damage.
Cheers
julius_makewar is offline   Reply With Quote
Old 09-23-2008, 08:08 AM   #3
Suspended
Cheers
X1
Pretty simple concept really, they don't call them servoSAVERS for nothing.
cracka is offline   Reply With Quote
Old 09-23-2008, 08:11 AM   #4
boostfiend's Avatar
Mike
Sounds like the servo saver was loose to begin with.
boostfiend is offline   Reply With Quote
Old 09-23-2008, 08:14 AM   #5
Akhor's Avatar
Why do most buggy drivers run those metal arms directly on the servo then?
They don't care about blowing them?
Akhor is offline   Reply With Quote
Old 09-23-2008, 08:23 AM   #6
CaLaBeR's Avatar
LMFAO There still is a spring in the akerman if you use a Aluminum servo arm.... They use these so there is less chance of loss of steering due to a plastic arm stripping and aluminum does not strip unless you install it improper... Also your spring is not tight enough if you cannot turn good tighten it up and you will be good to go..
CaLaBeR is offline   Reply With Quote
Old 09-23-2008, 08:23 AM   #7
razzor's Avatar
The std Caster servo saver spring is a bit soft but just tension it up and it will be good.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 09-23-2008, 08:37 AM   #8
Suspended
To an extent yes, they also run servos that are way beyond the needs of the buggy (torque) or its steering capability. At the same time the designs have extra linkages built into the steering that absorb a lot of the shock that if they had less they'd probably require a servosaver.
RCabcs is offline   Reply With Quote
Old 09-23-2008, 09:00 AM   #9
Akhor's Avatar
Oh this makes since (Sorry for the dumb question I'm a noob).
So what types of vehicles should run a servo saver then? And should it only be on the steering linkage?
Old 09-23-2008, 09:11 AM   #10
boostfiend's Avatar
All of them! hehe. Good servos (which everyone should run) are not cheap. The throttle servo doesn't require a servo saver.
If you don't know, all a servo saver does is provide a 'weak link' in the system that will give before the servo gears, splines, or links. A good servo saver will react to a harsh impact and reset itself.
Too loose of servo saver and it'll react under light conditions, like ruts, bumps and jumps. When it does react, it will change the toe angle of the tire. You certainly want to keep the toe adjustment consistant.
Too tight of a servo saver and you risk damage to the gears (or motor) of the servo. They can only take so much before they strip or burn. Not to mention, if the servo takes a hard hit and there is no give, it puts a heck of a strain on the battery and receiver.
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 05:09 AM
Pantoura, 1/10 Pan Car, 2S LiPo, Brushless, Tips and Tricks. John Stranahan Electric On-Road 2178 12-01-2010 10:26 AM
1/8 electric bharrill Nebraska/Iowa Racing 333 08-01-2010 07:45 AM
EP 1/10 Touring zafira2310 Indonesia Racing 10142 06-18-2010 11:09 PM
"Tamiya Class" racing...Help me choose - TA05 vs TA05R pgeldz Electric On-Road 84 08-09-2008 09:03 PM
Oh boy, noob Dad needs advice.......... SubSailor Electric On-Road 23 12-16-2005 07:34 AM
The New Malta Guys Race Chat 10malta Malta R/C Racers 679 11-15-2004 08:19 PM
