Old 09-29-2008, 03:10 AM   #16
vladconnery's Avatar
Trader Rating: 35 (100%+)
Originally Posted by mike williams View Post
well, i love it. runs great and it's not completely tuned yet. how do i determine it the (lsn)idle/air is to fat. it seems a little loaded when i give it gas, but seems good every were else. 240-250 f all day and i got about alittle more than 6 min on a tank...i'm wondering if i need the RB pipe. i have a dynamine 086 pipe. just wondering.
After you get her warmed up do this. Let her sit for 20 sec. then punch it there should be alot of smoke and she should clear out and take off. If she takes off immediately to lean. If she bog or cuts out to rich. My lsn is only about 2 hours from factory. Remember though thats my S3 and every S3 is as different as a finger print. mine runs great at 240 that does not mean yours will. Keep in mind this info posted here is general info it does not mean that thats how yours should be tuned or react. Remember your tuning mike williams engine not vladconnery's engine.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 09-29-2008, 04:30 PM   #17
230-240 is about right for the S3. If you can get Werks 30%, try that fuel as it really works well with RB engines. Once the motor has about 1.5 gallons on it, the top-end will go up and the temp will drop.
Inside_Line is offline   Reply With Quote
Old 09-29-2008, 07:42 PM   #18
mike williams's Avatar
Trader Rating: 45 (100%+)
p.s. im using Nitrotane 30%
LOSI MF2 ....... too fast for me!!!!!!!!
mike williams is offline   Reply With Quote
Old 09-29-2008, 10:22 PM   #19
Fear's Avatar
Send a message via AIM to Fear
I'm split on shimming. On some engines, they do the trick, on others..... not so much. I shimmed my S7 while moving up to 30%, and the darn thing wouldn't go above 215 degrees, and became a tuning nightmare. I have since removed the shim, running 3011 Byron Gen2, and hitting my 245-255 mark with ease, and very little tuning. My plug life is good, the internals have looked great on every teardown, and it runs as good as it probably ever will.
Experiment. Start with a shim, and if it works -- awesome! If not, take it out, or shim lower.
Robitronic Avid
MambaMax 7700kV, LiPo, JR Z9100S
Associated RC8
RB S7, JR Z9100S/Z9100T(nuked, at JR for repair)/Futaba BLS-351
Futaba 4PK
Fear is offline   Reply With Quote
Indonesia RC Car Talks MissX Indonesia Racing 6361 06-19-2010 02:07 AM
Just a question about a few .21 mills HarKonnenD Nitro Off-Road 2 05-16-2008 05:42 AM
newb question but can you drill holes in your fuel tank busta774 Nitro Off-Road 10 04-13-2008 08:44 PM
newbie .21 nitro question downunder23 Electric Off-Road 8 07-06-2006 10:15 AM
Help! Max modeified .21 fuel high conmumption US_MATRIX Onroad Nitro Engine Zone 8 03-04-2006 06:20 AM
