Old 09-19-2008, 07:57 PM   #1
rjs_13203's Avatar
Default stalling motor
having a problem once it gets some temp(around 200-230) it wants to stall. its a 427 with a MC-9 plug and running O'Donnell 30%. could it be that i need a warmer plug? or maybe not a good tune? also once it stalls it doesnt want to start back up.any suggestions
"You ain't seen nothin yet"
rjs_13203 is offline   Reply With Quote
Old 09-20-2008, 04:08 AM   #2
How much fuel have you run in it? Could be father time has got you. And could be air leak some where. The list of could be's is long and hard to do with out more info. First, richen up the HS a little. How old is the glow plug? They do go bad after a while. Why do you think they cost so much? Try this and get back to us soon and let us know.
The Working Man is offline   Reply With Quote
Old 09-20-2008, 04:35 AM   #3
When does it die? When accelerating, braking, coasting as these can all be caused by different problems.
JLinney is offline   Reply With Quote
Old 09-20-2008, 04:43 AM   #4
vladconnery's Avatar
Trader Rating: 35 (100%+)
Been down this road before. If it only starts and runs when it cool thats trouble. Usually the sign of an engine thats soon to be a paperweight.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 09-20-2008, 05:23 AM   #5
rjs_13203's Avatar
only dies when its idling
Old 09-20-2008, 05:31 AM   #6
Suspended
Could be all sorts of things, included what you said, but without more information any suggestions would just be wild speculation.
cracka is offline   Reply With Quote
Old 09-20-2008, 05:49 AM   #7
rjs_13203's Avatar
less then a gallion on it, brand new plug. going to check the tank later and also probably but new lines. someone also told me to lean it out cuz i have been running it rich, since everyone says its better to run it rich. also this is my first nitro engine so it is probably user error. also i cant really get it to sustain an idle to well.
Old 09-20-2008, 05:55 AM   #8
Now is the time to Google Ron Paris Racing
Old 09-20-2008, 05:57 AM   #9
rjs_13203's Avatar
i have read through that was just looking for an outside opinion
Old 09-20-2008, 07:35 AM   #10
Suspended
so which is it, when it gets to 1/2 a tank or when it gets warm?
Old 09-20-2008, 07:37 AM   #11
rjs_13203's Avatar
i want to say at like half a tank, im about to presure test the tank. and at a half a tank it running about 200-230. also doesnt want to start back up after it stalls
Old 09-20-2008, 07:42 AM   #12
Suspended
The problem is, like I said above, it could be all sorts of things and asking here is just going to make the problem worse because anyone has been given such little information they're just guessing as to the answer because you really haven't given enough information to diagnose the problem.
Then when you start two entirely different threads relative to the same issue but stating different reasons, it further clouds the issue.
I understand you're a rookie, but all you're going to do is just chase your tail with anything you get here.
You really need to take it to someone experienced so they can put their hands on it.
Old 09-20-2008, 07:45 AM   #13
rjs_13203's Avatar
well the lid leaks air, so going to buy a new lid and see if that works. if not i will just start replacing things then, dont really know anyone around here so its up to me.
Old 09-20-2008, 09:44 AM   #14
the o rings are replacable i the tank opening i ,have glued a block under the springs to tighten up a lid that popped open a little ,when my daughters car would land hard on it's roof
153stars is offline   Reply With Quote
Old 09-20-2008, 10:13 AM   #15
Hey, good idea!
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15106 06-26-2017 04:07 AM
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 06:19 PM
Serpent 710 Ron C. Nitro On-Road 23347 03-16-2010 01:47 PM
Hyper TQ Black eninge help please??? HaraR40 Nitro Off-Road 11 05-29-2009 02:26 PM
