Old 09-23-2008, 04:55 PM   #16
Just JB weld it..
Orange RC8 with a bunch of crap in it.
largeorangefont is offline   Reply With Quote
Old 09-23-2008, 05:16 PM   #17
stump27's Avatar
jb weld is probably the easiest way to accomplish your goal. i would suggest doing something we used to do in our full scale 4 cylinder mod dirt cars when we had to run an oem differential. we would disassemble it and take the 2 larger spider gears out of the diff and clean all the oil off. then we would weld up one of the valleys between the teeth out smooth with the teeth. then skip two valleys and weld another one. do the same thing 180 degrees from that. we did both gears that way and put it all together with the smaller spider gears into the two empty valleys on either side. that way it was locked, but had a little play so it wasn't so hard on everything inside.
i think the same would work on an rc diff, but you should probably weld every 90 degrees since we use four small spiders......
stump27 is offline   Reply With Quote
Old 09-24-2008, 01:06 PM   #18
Originally Posted by Ralph Walters View Post
I make a center locker for the losi. I also make some other goodies for the losi that are oval specific.
The last thing you want to do is make the car a RWD, it will be undrivable and only do donuts.
How much for a center locker for my hyper 8.5?
blowpopracer is offline   Reply With Quote
Old 09-24-2008, 03:29 PM   #19
Ralph Walters's Avatar
Blowpopracer,
you have pm.
Innovative Designs Racing Concepts
Ralph Walters is offline   Reply With Quote
Old 09-24-2008, 11:45 PM   #20
ralph since you make them how much and what else do you have for the 8ight
Camberlink is offline   Reply With Quote
Old 09-25-2008, 06:25 AM   #21
Please e-mail me at
rwalters163@msn.com
if you are interested in the Losi diff options.
Old 09-25-2008, 10:54 AM   #22
I think the main gear box from an Ofna Monter Pirate would work. It is basically a steel shaft with the spur gear mount welded on. The ofna pirate was a 4x4 buggy which is the predecessor to the Hyper buggies. The moster pirate replaced the center diff with a live shaft on bearings. It is just a solid shaft on bearings with a drive cup at either end. Nitro house has them and they look like they run about $14.00 I have a ,monster pirate and a hyper 7 and it looks like this is what they did. It would work well. Then all you would have to do is take the drive shafts off your from CVD so the axle stubs would free wheel in the bearings. The bad thing is that you would only have brakes on your back wheels.
billm67 is offline   Reply With Quote
Old 08-14-2012, 10:18 AM   #23
will this locker fit into the 8ight buggy??
http://www.amainhobbies.com/product_...ial-Lock-Spool
2 HPI bajas, E-firestorm with VXL, ax10, kyosho scorpion xxl with mamba monster,3 axial wraiths, rc4wd gelande, axial scx10, rc4wd tf2, Gas boat, shockwave26 boat, Phinix trainer plane, bixler FPV, honey bee heli
ektoz is offline   Reply With Quote
Old 08-15-2012, 01:03 AM   #24
GT4Point6's Avatar
This is one of the simplest tuning tools you can use for oval racing. The Differential Spool insert replaces the spider gears in your center differential essentially making it a transfer case which sends full power to both the front and rear differentials full time.
http://www.losi.com/Products/Feature...rodId=LOSA3609
$12 , not bad...
Kevin,
Losi 8ight-T 2.0/Werks B5 Pro
Losi 8ight-T 2.0/JS .21
AE Monster-GT/LRP ZR-30X
HPI Baja 5SC SS/OBR 27.2 Prostock
GT4Point6 is offline   Reply With Quote
8IGHT 2.0! BAUSTIN Nitro Off-Road 14679 09-12-2015 07:58 AM
Don't buy MP9 Dale14 Nitro Off-Road 155 03-07-2009 08:28 PM
