Old 09-17-2008, 03:45 PM   #1
Default Why Servo Grommets?
Do you use the rubber o-ring servo grommets supplied with your servo? OR do you just mount the servo right on with screws?
I've heard both... people sware you need to use the grommets to protect the servo from being stripped... other people say if you use the grommets there is too much slop...
what do you do and why?
Don Duct is offline   Reply With Quote
Old 09-17-2008, 03:59 PM   #2
Trader Rating: 36 (100%+)
I use em. It's always been my belief that they are used to help prevent vibration from messing with the servo.
NitroOB4You is offline   Reply With Quote
Old 09-17-2008, 04:49 PM   #3
jpz_67's Avatar
Trader Rating: 56 (100%+)
Use them for sure. It is a cushion for the servo and helps to prevent cracking the ears off the cases. I used to occasionally crack on of the corners off of my servos until a friend told me to start using the supplied grommets. Ever since no more broken ears.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 09-17-2008, 05:22 PM   #4
imaxx21's Avatar
Send a message via AIM to imaxx21
i use DACE servo clamps, nothing better IMO
http://www.rccompound.com/SearchResults.asp?mfg=Dace
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 09-17-2008, 06:01 PM   #5
technazi's Avatar
With all the vibrations occurring in cars it's a wonder that the electronics work at all. Certain things just don't go well with electronics.... water, heat, and vibration.
I'm all for using the rubber grommets, but only in conjunction with the brass eyelets that are placed inside of them. If you can eliminate the vibration to the electronics in the servos, you may find they last longer and protect the gears better. When using the eyelets in the center of the grommet, the servos don't have much room to move around if everything is secure.
Using only the rubber grommets, your servos will definitely have some slop.
technazi is offline   Reply With Quote
Old 09-17-2008, 06:21 PM   #6
wingracer's Avatar
Trader Rating: 23 (100%+)
Use them on throttle servos, but like the other guy said use the little eyelets too.
You usually can't use them on steering servos due to mounting and geometry issues but if the car is designed for them then it should be ok.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-18-2008, 10:30 AM   #7
Akhor's Avatar
I've been using the gromments, but without the eyelets... Didn't actually know that they were supposed to go in there.. Guess what I'll be doing this evening?
Akhor is offline   Reply With Quote
Old 09-18-2008, 11:21 AM   #8
wild gopher's Avatar
Trader Rating: 39 (100%+)
my eyelets are never big enough to fit the screws that I use for mounting the servos
RCtech - Filling me with adult drama since 2003
wild gopher is offline   Reply With Quote
Old 09-18-2008, 11:23 AM   #9
ive also never run grommets in the many years ive been racing and have never broken an ear or a servo....that is until I started running a losi lol
Old 09-18-2008, 11:33 AM   #10
Trader Rating: 21 (100%+)
Since I started using servo clamps, I've not broken any ears. I've never had a servo go bad either with or without the clamps. I looked at the grommets and eyelets and they were not compatible with the screws I use so I don't use them.
Duster_360 is offline   Reply With Quote
Old 09-18-2008, 12:55 PM   #11
Akhor's Avatar
Anyone else make these servo clamps besides Dace? I cann't find any on A-Main.
Old 09-18-2008, 08:16 PM   #12
Thanks for all the feedback.
I use to race 1/10 scale electric and I never use grommets and I never stripped or broke servos.
I ask because I now race a Losi 8ight and had a nice JR 9100s servo mounted. The servo gears blew up. I was curious if the grommets would have prevented that. I am very confident I had the servo adjusted properly. The odd part is that putting grommets on the 8ight it seems to throw off the geometry and make the servo sloppy not being mounted firmly.
Thankfully JR fixed my servo as a courtesy.
-Don
Old 09-19-2008, 06:56 AM   #13
Akhor's Avatar
-Don
Ya, JR's 3 year warranty is hard to beat!
Old 09-19-2008, 07:00 AM   #14
RickBac's Avatar
Trader Rating: 20 (100%+)
One other reason for using the rubber grommets is to help reduce glitching. I know on modern radios it is not as necessary but it is cheap protection.
Losi XXX-CR
LRP Sphere Brushless
HB D8
Trinity .21
Airtronics
RickBac is offline   Reply With Quote
Old 09-19-2008, 07:02 AM   #15
Suspended
ROFLOL
cracka is offline   Reply With Quote
Kyosho v-one rrr doki_doki Nitro On-Road 9839 08-07-2014 03:59 PM
Team Associated 1/8 scale Buggy Info and Tips Kevin Boyle Nitro Off-Road 11189 03-12-2013 05:52 PM
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 08:43 AM
1/8 Offroad Buggy Mercury Racer Electric Off-Road 1510 12-05-2006 03:05 PM
Throttle/brake servo broke... again!!! (3rd replacement!) sonep Malaysian R/C Racers 25 10-01-2003 07:27 PM
