Old 09-17-2008, 12:59 PM   #1
Maximo's Avatar
Default Prefered track surfaces ?
I am curious as to what everyone's preferred track surface is....Where I run the track is just made from black dirt, it works okay but it is very far from ideal....Our club is growing and its time to be considering a new facility and track surface..... I am rather lost as to what all the different options are as well as any different pro's and cons....We obviously want some type of clay track, some of our club have suggested using pure clay others say you must make a mix using clay and other substrates... Where we live we do have an abundance of very fine grey colored clay, the stuff will dry so hard that chunks will have a semi polished sheen to it... we also have huge amounts of black top soil and fine white sand...... We have unlimited water supply and would be willing to build a sprinkler system if we needed to keep the surface moist .......Anyways any suggestions and advice would be greatly appreciated
http://www.thenitroshop.com/
Maximo is offline   Reply With Quote
Old 09-17-2008, 01:49 PM   #2
mtbkym01's Avatar
Trader Rating: 26 (100%+)
My club is about to commence construction of a brand new facility and track. Where we are located, the natural ground is primarily red volcanic clay/soil, (Very similar in appearance to the "Farm2" surface.) Another track about 4 hours away is constructed out of decomposed granite, and although it hooks up very well when slightly moist, It is very abrasive on chassis and skid plates.
~Kym Nuske~
RCHobbyzone.com.au / Model Motorsports International
Mugen Seiki 1/8, Reds, Neo+ Fuels
AE 1/10, Reds
"If it's old skool, it's kool"
mtbkym01 is offline   Reply With Quote
Old 09-17-2008, 02:02 PM   #3
desertbird's Avatar
dirt
desertbird is offline   Reply With Quote
Old 09-17-2008, 02:29 PM   #4
Suspended
Send a message via AIM to Nay0k
Air
Nay0k is offline   Reply With Quote
Old 09-17-2008, 02:44 PM   #5
D8
D8's Avatar
it does not make any difference to me....
D8 is offline   Reply With Quote
Old 09-17-2008, 03:03 PM   #6
wingracer's Avatar
Trader Rating: 23 (100%+)
1. Asphalt
2. Carpet
3. Moist, blue groove red clay.
4. Concrete.
5. The best dirt I ever raced off road on was some really soft, loamy, black stuff the track owner found somewhere. Monster traction and low tire wear. The only problem was that the tires would turn green and it had a bit of a foul smell. I don't want to know where that nasty stuff came from.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 09-17-2008, 03:25 PM   #7
D8
D8's Avatar
cow crap....
Old 09-17-2008, 03:44 PM   #8
Owen RaCing's Avatar
Trader Rating: 17 (100%+)
Soft, loamy, loose, wet, DIRT!
powered by anti-anxieties, sarcasm and chipotle
Owen RaCing is offline   Reply With Quote
Old 09-17-2008, 04:25 PM   #9
Fletcher6371's Avatar
Clay and mixture of sand. My local track is by a river that has flooded 3time this summer. so we have a LARGE sand content which makes it hard to get traction, but a lil sand is good.
FlatBusted Racing
Dialed Inc., North Central Hobbies, Competition Heat, FUnS Racing lol
Fletcher6371 is offline   Reply With Quote
Old 09-17-2008, 04:35 PM   #10
Bob Malphurs's Avatar
Good ole Georgia red clay!
Bob Malphurs is offline   Reply With Quote
Old 09-17-2008, 04:40 PM   #11
Consistent Loose Dirt.
What's the point of running off-road and striving to have a surface with perfect traction like on-road? Can't even drift around corners.
shurcooL is offline   Reply With Quote
Old 09-17-2008, 04:45 PM   #12
jpz_67's Avatar
Trader Rating: 56 (100%+)
It depends on the situation. For just a club race where you have fun with your buddies and enjoy yourself, a correctly watered dirt track is the way to go. It keeps everyone happier this way. Examples less wear and tear on your car, less tire wear, minimal if any dust, less filters being used, and the improved traction makes it easier for all drivers to hammer down and have fun.
For a major event I think a dry track is the way to go, this way everybody gets the same track. If you race outdoors and an event is run wet, unless you frequently water not every racer will get the same track. Not everyone can go as fast on a dry track vs wet track and vice versa. Just my .02
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 09-17-2008, 04:55 PM   #13
Trader Rating: 33 (100%+)
That would be my choice, they used to truck that stuff in for the winternats in Tampa. We would have so much traction by the end of the weekend my truck would wheely and almost flip if I mashed the throttle going onto the straight!
chensleyrc1 is offline   Reply With Quote
Old 09-17-2008, 07:08 PM   #14
chrobar's Avatar
There is both an indoor and outdoor offroad track at my nearest track facility. I prefer the indoor because it's super high bite clay, and very technical. The track makes for really fun racing, and it isn't dusty/muddy. Plus it's the track that I have the best tires for (boa clays). The outdoor track is the usually farm dirt that eventually blue grooves up and gets rutty. It can be hard on tires, and it's never really consistent. At first it's muddy because of the watering, then it gets dusty, and then rutty, and then hard blue groove that's kind of dusty.
CEN Factory Team
Matrix C-1 FRE custom brushless, 2000kV, Orion VDS-2015
GST-E, 1500 kV, Hitec 5955TG
Futaba FASST 3PM
chrobar is offline   Reply With Quote
Old 09-17-2008, 11:14 PM   #15
IanWright's Avatar
Location: If i'm not in England i'm in Southern California
Send a message via AIM to IanWright
You have to race on astroturf to understand the kick. Like outdoor carpet racing with jumps and bumps...
IanWright is offline   Reply With Quote
Clay Track Surface Maintenance! Blackie001 Nitro Off-Road 19 07-20-2009 09:25 PM
Tire choice for parkinglot racing????? Fiream Nitro On-Road 207 04-25-2005 06:19 PM
