Old 09-14-2008, 06:09 PM   #1
ZH
Default problem with my savage x 4.6
i have a savage x 4.6 and the last time i ran it it was only working in front wheel drive. can you please tell me what i can do to fix it?
thanks
ZH is offline   Reply With Quote
Old 09-14-2008, 06:23 PM   #2
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
Check your driveshaft going from the transmission to the front diff.
crazy4wdracer is offline   Reply With Quote
Old 09-15-2008, 09:07 PM   #3
ZH
i checked the driveshaft but that wasn't it. i also took the transmission apart and when i opened it up there were metal shavings all over. i checked all the gears and took them apart and cleaned them and put it back together. after it was put back together, i get this grinding noise when i push it. i cant figure out what it can be.
Old 09-15-2008, 09:23 PM   #4
is the noise coming form the trany or the rear end. you may have took out a rear diff.
badxlt is offline   Reply With Quote
Old 09-16-2008, 10:08 AM   #5
HiLuckyB's Avatar
I would take a look at the rear diff.
HiLuckyB is offline   Reply With Quote
Old 09-16-2008, 06:51 PM   #6
ZH
I took the rear differential out and it looks like the bearings went out on it. Do you know if HobbyPeople sells replacement bearings for the diff and a replacement gasket, or do I just have to buy a brand new differential?
Old 09-16-2008, 08:52 PM   #7
offr0aden's Avatar
Yes .. you can get the bearings or the gears ... I'm guessing the stock rear diff went out. Is the pinion and ring gear ok? Also, it's a must to shim the diff closer to the pinion to tighten up the gear mesh other wise when under load the plastic diff housing will flex and you will chew up the teeth. I've been racing savages for a long time, and HPI released a upgrade diff kit with aluminum diff housings and spider gear shims to tighten the mesh in the diff and prevent flexing internally. I can't find the part number for this kit, but I know that you can get the parts to build one. I'll look once I get home for the part number and post it.
I'm curious as to what gear went out. That will tell a lot of what you need to do when you rebuild it. The other option is to buy a complete diff, but I would go through it and of course shim it.
Here's the diff parts sheet... this should help find the parts that failed.
offr0aden is offline   Reply With Quote
Old 09-21-2008, 07:28 PM   #8
ZH
I took the differential apart and the only thing that was wrong was the bearing went out. everything else was perfect. i repalced the bearing and put it back together and started it up and it runs perfect.
Thanks for helping me out.
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 05:16 AM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
HPI Savage X SS or XL EastCoasterVa Monster Trucks 19 11-24-2008 02:47 PM
HPI SAVAGE-X Thread. Artificial-I Monster Trucks 138 11-06-2006 08:39 AM
MGT vs SAVAGE X big-al Monster Trucks 53 08-22-2006 11:28 AM
my t-max is eating my savage X bigD270 Monster Trucks 67 03-31-2006 05:54 AM
