Old 09-07-2008, 02:56 PM   #1
t0adman's Avatar
Default Hanging clutch shoe - replace or repair?
I have a clutch shoe that's hung up...again. I'm going to replace the springs since they're causing the problem but I'm curious if I need to replace all the shoes. One is obviously worn more than the others. If it's not in terrible shape can I get away with running two slightly larger than the third?
t0adman is offline   Reply With Quote
Old 09-07-2008, 02:59 PM   #2
jrwoodchuck's Avatar
change em! Both springs and shoes, you'll be wishing you did it if you don't.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 09-07-2008, 03:08 PM   #3
stump27's Avatar
be sure that the shoes move freely on the flywheel pins without the springs on them.... even with new shoes. sometimes the holes are a little tight and need opening up a small amount with a dremel. also, check your pins on the flywheel, they wear sometimes and require either replacing the pins or tossing the flywheel altogether.
stump27 is offline   Reply With Quote
How often do you replace Clutch Shoes? Don Duct Nitro Off-Road 3 05-09-2008 12:08 PM
CLUTCH SHOE Ivan Dickson Nitro On-Road 5 01-29-2008 02:55 PM
how to replace the clutch bell jacked up truck Nitro Off-Road 1 09-03-2007 06:56 AM
new 4 shoe clutch roketman Electric Off-Road 3 01-30-2007 07:21 PM
Should I Repair or Replace my Servo? The Nutter Australian Racing 11 02-18-2004 02:37 AM
