Old 09-02-2008, 06:06 PM   #1
Default Changing Differential Oil.
How do you change your differential oil? Once you open your differentials do you take out the gears and clean them up and wipe out the differential? And how much oil to you put into the differential? Enough to just cover the gears or fill it up to the top?
Captpete is offline   Reply With Quote
Old 09-02-2008, 06:07 PM   #2
jrwoodchuck's Avatar
Yup! you hit it, cover the gears. Let it sit for a couple of minutes so it will settle, then top off if needed.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 09-02-2008, 07:12 PM   #3
Trader Rating: 21 (100%+)
I wash everything off using denat alcohol. Cover the spyder shafts. If I'm using something real thick, I'll give it a few minutes to settle too. Then top off back to just cover spyder gear shaft.
Duster_360 is offline   Reply With Quote
Old 09-02-2008, 07:20 PM   #4
Denatured alcohol works, but I like to use naphtha for cleaning old diff oil out.
Semple is offline   Reply With Quote
Traxxas Revo futureal Monster Trucks 3272 04-30-2017 03:46 PM
PUTRAJAYA OFFROAD TRACK azmin Malaysian R/C Racers 1064 05-24-2013 08:32 AM
1/8 scale off-road Electrics adrictan Singapore R/C Racers 6612 06-12-2012 05:02 PM
EP 1/10 Touring zafira2310 Indonesia Racing 10142 06-18-2010 11:09 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 07:19 AM
