Old 09-02-2008, 11:12 AM   #1
t0adman's Avatar
Default How do you drill your wheels or tires?
I've seen video tutorials that show that you should drill 3 or 4 holes on the inside of the wheels, which is what I've been doing. Last week at the track a guy loaned me his JConcepts Hit Men and I noticed he drilled 3 or 4 holes in the center of the tire tread. When I asked him about it he said that way any dirt or moisture it thrown out of the tire when running instead of trapped inside.
How do you drill your wheels or tires and what have you found works best?
t0adman is offline   Reply With Quote
Old 09-02-2008, 11:15 AM   #2
imaxx21's Avatar
Send a message via AIM to imaxx21
use a leather punch for the tires...
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 09-02-2008, 11:17 AM   #3
imaxx21's Avatar
-Crash
Old 09-02-2008, 11:20 AM   #4
Trader Rating: 20 (100%+)
An x-acto or drill bit works best for the wheels. A leather punch is by far the best way for the rubber tires but an x-acto knife works fine to "cut" holes in the tires. Basically you stab the tire four times in a square pattern and pull out a little cube of rubber. I usually put 2 holes opposite from each other in the tires for the same reasons - it lets out any notable moisture from the centrifugal force. I also put a few like 1/8th inch holes in the wheels for venting so the tires can compress over bumps.
-Jeff
JeffEmbracedDC is offline   Reply With Quote
Old 09-02-2008, 12:29 PM   #5
jrwoodchuck's Avatar
Originally Posted by imaxx21 View Post
+1 their $7.00 at hobby lobby.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 09-02-2008, 01:44 PM   #6
jerobert's Avatar
Toadman, did he really have bad grammar when he told you what to do?
Also, thanks for the reply fellas with respect to the tools.
Am I reading that you suggest doing the inside of the wheels and outside of the tire?. Doesn't the outside of the tire release the air so that the inside wouldn't be necessary?
RC8
SC8
Slash
jerobert is offline   Reply With Quote
Old 09-02-2008, 01:54 PM   #7
I just do the tire, not the rim.
Doug
TLR 22/M-11
Old 09-02-2008, 02:36 PM   #8
Trader Rating: 24 (100%+)
i block the holes up on the wheel and use the punch on the tyres
meakinracer is offline   Reply With Quote
Old 09-02-2008, 03:11 PM   #9
SteveJa's Avatar
Trader Rating: 17 (100%+)
+1 for this..... makes the foams last longer......
SteveJa is offline   Reply With Quote
Old 09-02-2008, 06:48 PM   #10
Integra's Avatar
x2...our track has alot of Loose fluff...that works its way in through the rim holes and takes out the foam Real fast.
Old 09-02-2008, 07:37 PM   #11
Holes in the tires for outdoor and holes in the wheels for indoor when there is little to no dust. With holes in the wheels only outdoor racing your tires will fill with dirt and weigh a ton and become very unbalanced.
The reason I put holes in the wheels for indoor racing is because we normally wash the tires after every run and they don't get full of water with the holes in the wheels.
gasser is offline   Reply With Quote
Old 09-02-2008, 07:47 PM   #12
I forgot about indoor. You're right, indoor in the wheel, outdoor in the tire. That is how I do mine.
Doug
TLR 22/M-11
Old 09-02-2008, 10:16 PM   #13
air8's Avatar
A dremel, drill bit, or body reamer can be used on the wheels. And I do the same thing with my vehicles. Holes in the tires for outdoor, holes in the wheels for indoor.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 09-03-2008, 08:29 AM   #14
Steve Walters's Avatar
+2
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Old 09-03-2008, 08:51 AM   #15
wow i feel dumb cuz ive never heard of drilling holes in the tires.
please expalin to what the difference between a hole in a tire and a hole in the rim does
www.nitrojunction.com
The #1 site for all your nitro needs
egobuster1 is offline   Reply With Quote
Oshkosh Racing HALFFAST Wisconsin & Illinois Racing 7667 07-15-2017 06:46 PM
BMI's DB12R Mr. Shookie Electric On-Road 8730 02-11-2017 11:12 AM
Veteran TAMIYA TA03 fans! porkybmx Electric On-Road 1496 08-12-2016 06:02 PM
Indoor Carpet Setup: Emaxx? mr. chicken Monster Trucks 16 07-14-2003 10:05 AM
