Old 09-02-2008, 09:05 AM   #1
supralative's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to supralative Send a message via Yahoo to supralative
Default Gearing, gear ratios, benefits...???
Directed toward buggy drivers mainly. The Jammin upgrades do it, from going with standard straight cut crown and pinions, to the spiral cut along with the smaller tooth count on the pinion. It can be on the Kyosho as well using the STRR stuff. What is the true benefit of doing this? What does it let you change on clutch bell and spur gear count also?
Son N.
www.hyperspeedmotorsports.com
www.oklahomanitroclub.com
supralative is offline   Reply With Quote
Old 09-02-2008, 07:55 PM   #2
well yeaaaaaaaaaaaaaaa buddy
Son N.
Old 09-03-2008, 03:49 PM   #3
that's what i am talking about
Son N.
Old 09-03-2008, 04:25 PM   #4
jpz_67's Avatar
Trader Rating: 56 (100%+)
I dont completely understand your question but here I go. The benefit from running spiral cut vs straight cut gears is strength. There is more surface contact with helical cut(spiral cut) gears. They also last longer. Now as far as gear ratio changes such as getting a lower internal ratio with the ring and pinions, this offers more gear ratio combinations as well as improved acceleration while retaining a good top speed. I recently just went through this with my mugen buggy. I run a 4.60 ratio in the front and rear then a 16/44 combo on the clutch bell and spur. My final drive comes out to be a 12.65, the car really has good bottom and still a good top speed. The most noticeable feature of having the lower gear ratio is coming out of the turns, it seems that I hardly have to get back in the throttle as compared to running the buggy gears. It is not necessary but if you notice several of the major manufacturers are starting to gear there cars down, the hyper 9, 808, Rc8, HB D8, all these biggies feature a 4.30 internal gear ratio. Even the mbx6 has a new gear ratio but not sure how they did it. Hope this helps.
Agama A215, Futaba, Nitro Pro Fuel, Proline tires, Triton Engines, Savox.
jpz_67 is offline   Reply With Quote
Old 09-03-2008, 05:13 PM   #5
WAHOO!!!!!!!!!!!!!
Thank you
I new the strength factor, but was not sure on the benefit of gearing and how it worked. I have been contemplating of doing the change, but was not sure if the cost would offset the benefits.
So if I do run the spiral cut gears, what should I do on the clutch bell/spur gear combo? Go bigger on the clutchbell and smaller on the spur gear or vice versa?
Son N.
Old 09-03-2008, 06:09 PM   #6
depending what it is you want to gain.
I personally change out my spur gears every so often, depending on track layout. Like for instance, if i raced on a large track, i would run a 50T spur but leave my 13T clutchbell, then if i raced on a small to medium sized track, i would run my 52T spur and my 13T clutchbell.
you can also conserve fuel by gearing your motor to the track setting...
some just change clutchbells, but i found changing my clutchbells to be more of a drastic change, you can do more of fine tuning with your spur gears.
I also noticed some people dont change a thing and leave it as is for every track setting...but change their clutch's instead, or pipes, headers and so on...but just like scale sized racing, they adjust their gearing depending on the track...such as moving from a road course to an oval track like fontana. Certain NASCAR teams will have a TOTALLY different car for certain tracks...and even different drivers!
I understand this is just RC racing, but im sure you can gain the same benefits from what you see and hear from NASCAR, F1 and so on...
it only but makes sense i guess is what i was trying to say LOL some do and some dont...
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 09-03-2008, 07:23 PM   #7
jpz_67's Avatar
If you decide to run the truck gears in your buggy it is also going to depend on the spur gear your are going to run. No matter if you run the 46 or 48 spur plan on running a bigger clutch bell. If it were me I would start with a 16/46 or 17/46 clutchbell/spur combo. I think the kyosho buggy is lighter than a mugen and would not need as much gear to get moving. the 16/46 would yield a 12.36 final drive and the 17/46 would get you to 11.66. It will take a little trial and error to get it right but I am glad I did it. To find your gear ratio just divide the clutchbell and spur, then divide the pinion by the ring gear, multiply the two totals together and you have your gear ratio. Example 16/46= 2.875, 10/43= 4.30, 4.30x2.875=12.3625
Old 09-03-2008, 08:08 PM   #8
forgot to mention i was referring to my truggy not buggy.
Serpent 705 J_Longbrake Nitro On-Road 4252 02-22-2015 11:34 PM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 12:16 PM
