Old 08-29-2008, 05:00 AM   #1
CtK
Default Fuel coming out of tuning Pipe??
I was running my Losi 8ight at the track last night and the first 3 tanks it ran fine. But then I let it kewl a bit and I couldn't get it freaking started, so I turned it over on its side for some reason and all this fuel started coming out of the tuning pipe?? Why did this happen??
thanks!!
CtK is offline   Reply With Quote
Old 08-29-2008, 06:16 AM   #2
Send a message via MSN to DirtRacer
well it is possiby some oil and fuel that has been sitting on the bottom of the engine, just put the buggy on the starter box and place the glow plug in burn all that nitro out and then refuel and start it up, should be fine, prime the engine so that the plug has somthing to ignite and it ll start the engine right away. have fun and dont stop asking. good way to be in the know and make sure its the right info...but what ive said im sure you ll be ok.
RollingDist46
extreme sports and more....
www.myspace.com/m1urathanedist46
www.myspace.com/renegadebearingsdist46
DirtRacer is offline   Reply With Quote
Old 08-29-2008, 06:27 AM   #3
CtK
well it happen every time i would turn it over on its side till the gas tank was empty
Old 08-29-2008, 06:37 AM   #4
Is it a new engine? if so it may be still too rich with breakin settings.I've seen this when doing breakin
Hixie is offline   Reply With Quote
Old 08-29-2008, 06:55 AM   #5
CtK
its a Go Tech .21 5 Port...has about 10 tanks through it.
I mean a lot of fuel comes out of the tuning pipe
Old 08-29-2008, 07:01 AM   #6
Well you have pressure tube going from pipe to tank right ? So there's your path for fuel
Poinas2 is offline   Reply With Quote
Old 08-29-2008, 07:51 AM   #7
CtK
you think the fuel tank might be broken??
Old 08-29-2008, 07:58 AM   #8
GHETTOTEACHER's Avatar
There is nothing wrong with your pipe or engine. You are just a little rich. Also the oil content of your fuel is a little high. Just retune.
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
Old 08-29-2008, 08:24 AM   #9
Just as a rule of thumb I will tilt my buggy to the left just to drain out any oil/fuel out of the pipe after each tank. Since I'm new I didn't realized how much can accumulate in there with a new engine aftern it's been run rich for a bit.
rav_cherry is offline   Reply With Quote
Old 08-30-2008, 07:05 PM   #10
bjr48's Avatar
If none of this advice helps, I remember reading somewhere recently that technically the exhaust tip of your pipe should point down just a bit to allow it to drain. We're just talking a couple of degrees past level. Don't go overboard here or you will snap it right off when you land. I've never heard this before but if you have it aimed up a few degrees it COULD be your problem. I'd try everything else I could think of first though.
The only time I had an engine do a lot out the pipe is when it was completely worn out. But then again it was so worn that it wouldn't really start - it would just pump raw fuel through it!
bjr48 is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 08:46 AM
Carb - Impossible tune. Orangetang Nitro Off-Road 22 06-19-2009 09:19 AM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 08:25 PM
