RB S5 L2G
RB S5 L2G
JUST GOT THIS MOTOR AND FINSHED BREAKING IT IN. DOES ANYONE RUN THESE MOTORS. LOOKING FOR ALL HELPFUL ADVICE NORMAL OPERATING TEMP TUNNING TRICKS ANYTHING THAT CAN HELP ME BE TROUBLE FREE AND KNOW THE MOTOR FROM THE START INSTEAD OF FIGURING OUT ON MY OWN
You won't see a RB's real power till after a gallon so be patient. I find that they need to be a tad rich on the lsn. A good test is to make sure it loads up when idle for 20 seconds. It should create alot of smoke clearing out the engine after a 20 second idle. Once you got the bottome end tuned hsn tuning will be a breeze. You won't have to worry about retuning to much as RB's hold a tune like a vise. Go easy the 1st gallon thats one of the drawbacks to RB's is long break in. Which corresponds with there upside of long life. Hope your running a Rb pipe as JP's tend to make them run hot. Go to the RB USA website and check there forum.
thanks
tabks for the tips guy i really appreciate the help yea jp 4 i used had motor around 260 270 mark thanks for that tip will get rb pipe
Well, since my OS failed I'm going to need a new engine sooner than I thought. This RB S5 is at the top of my list as of now but need time to seriously look at the competition. So what I'd like to know is how a REX EFRA 9886 will work with this engine becuase that's what I have available. And how do I measure my header to tell if I've got what's considered a short or long one?
I understand the theory of pipes but is the one thing I've never gotten into and fully understood. Need some help. I know it won't be the BEST choice but if I can measure my header and you can tell the the pros and cons of the 9886 with an S5 I sure would appreciate it!
Vladconnery, I also have a Go 7 port and when I can get that thing to run right it freakin screams. Problem is that I have been chasing a tune with that engine. Replaced all the variables you can think of and still had issues. Long story short, I bought a S5 L2G to replace the GO and wouldn't you know it, had problems with that too.
Your probably thinking that I am the problem, well that is one of the variables I eliminated. I have 5 master tuners at the track try and tune my S5 and it wouldn't tune. I sent it back to RB and I hope to get it back this week.
My question is how will the S5 perform with the Dynamite .053 pipe. Will it work well or should I buy a RB pipe. If so, which one do you recommend?
Back to the GO, turns out that I had two issues at once which is why I couldn't figure it out. Bad RC8 tank, (duh), and bad needles in the GO.
I am just trying to avoid buying another pipe if I don't have too. Your thoughts?
I would say as long as your not running a JP pipe. You will probally be ok with the .053. I have not run this pipe before. I do know that a JP+RB= Just keep in mind that a RB pipe is going to give you the best performance. I got my RB w/ header used for $40 here.
Good Luck
