Old 08-28-2008, 06:41 PM   #1
thecman26's Avatar
Trader Rating: 98 (100%+)
Questions?? OS Carb baseline settings?
I have a "moderately" modded OS RG that has had "8-10" tanks run through it for break-in.
I put it in my 8ight-t and tried to run it today and its actin all crazy....
Plenty of power, smoke, and it just wont idle... When I keep it running with my finger it temps in the 250's after 2 laps... I was just wanting to know if anyone knows the baseline OS carb settings so I can get started tuning...
I fattened up both ends and the temps came down but then it doesnt want to idle at all... I put a new plug in it (medium) so it cant be that...
Any ideas will be greatly appreciated...
Chris Keen: Viola, Kansas
FT T4.2, Kyosho RZ6, TLR 22 3.0, & 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-28-2008, 09:24 PM   #2
I have an OS Vspec VZB. Seems like a good place to start is LSN four turns out from bottom (all the way in) and HSN three turns out from bottom. Then begin to lean out from there.
I'm not an expert on the various engines/carbs yet so don't quote me.
Don Duct is offline   Reply With Quote
Old 08-28-2008, 09:27 PM   #3
thecman26's Avatar
Thanks, just cant find a lick of info anywhere else...
Old 08-28-2008, 09:28 PM   #4
Trader Rating: 29 (94%+)
I so 3.5 up from closed on both and I have no trouble at all. I hope this helps you out. See you next Sat
kcpipeliner is offline   Reply With Quote
Old 08-28-2008, 09:36 PM   #5
thecman26's Avatar
Thanks!
Hell yeah... See ya!
Old 08-28-2008, 10:25 PM   #6
thecman26's Avatar
One last silly question...
Here is a pic of the os carb, are both hi speed and lo speed valves on the same side? top and just below it...
If so whats the hex svrew on the other side (slide)
Old 08-28-2008, 10:28 PM   #7
No that is a 3 needle carb. The tall one is the high end and then one below that is called the mid range (normally never move it) and on the other side of the card where that black boot is there is a screw there and that is the low side
Old 08-28-2008, 10:31 PM   #8
thecman26's Avatar
Ooops... thats why I couldnt get it to run right, I was jackin with the hi and mid needles only...
Old 08-28-2008, 10:34 PM   #9
I guess I should have asked you if there is a screw on the other side where that black boot it. My first motor that I had didn't have a low end all you had was a high end but I have never saw a OS that didn't have all three needles
Old 08-28-2008, 10:45 PM   #10
thecman26's Avatar
Yeah its a hex screw thats what threw me for a loop
Old 08-28-2008, 10:58 PM   #11
I sent you a PM but I was just wondering if I could see a pic of the other side of the carb? I am pretty sure it is a 3 needle carb but it should not be a hex screw
Old 08-28-2008, 11:05 PM   #12
thecman26's Avatar
Ok
A lil blurry but the screw on the slide is a blk hex screw
OS Carb baseline settings?-pict0086.jpg   OS Carb baseline settings?-pict0088.jpg
Old 08-28-2008, 11:09 PM   #13
Ok
after seeing that it looks like maybe that aftermarket screw was needed but yes that is the bottom end and if you put your mid range needle back even with the carb body and the bottom end even or alil out from even you should be close.
Old 08-28-2008, 11:12 PM   #14
thecman26's Avatar
No wonder it acted lean, the bottom was ALL THE WAY in
Old 08-28-2008, 11:16 PM   #15
that will do it everytime I hope that helped you. You can still ask around if you would like I mean I am not the best or anything even close to the best but I have been hanging out with J P for the last 2 years or so, so everything I have learned has been from him and he had not shot me wrong yet
OS FS26S-C 4-stroke development mxwrench Offroad Nitro Engine Forum 1530 Today 04:57 AM
T/E Maxx Thread Modena AL Monster Trucks 619 05-19-2014 12:30 PM
Pro Twister Mods skeller Offroad Nitro Engine Forum 2306 08-23-2011 10:11 PM
This V-spec is driving me insane. Jonro Nitro Off-Road 95 03-30-2009 02:35 PM
OS 12 TzR romuald31 Onroad Nitro Engine Zone 1444 08-09-2007 01:50 AM
Base line settings for a OS .12TR crazyjr Onroad Nitro Engine Zone 13 08-04-2006 08:53 PM
