Engine Temp question ...input...
Hello well just after resetting up my engine yesterday and was racing all day today the engine ran excellent for the first time in ages getting 12 mins a tank so easily making the 10 min efra ruled heats without piting, 5 heats where ran today all of which i feel i did very well pushed hard and was rewarded, after 10 mins engine temps ranged from 112c to 121c
my question is tomorrow if i keep up the work the A final is 1hour long, should i richen my engine slighlty bought 1/8 high end
or will the tempeture it reaches after 10mins remian the same until 1 hour of flat out running is it the max/optimum temp it will reach?
if you understand what im asking.
thanks adam
thanks adam
thanks adam
thanks adam
personally I run the main harder than the quals. I richen my engine up 1/2 hour before the main. But if you drive the same in all races, I would leave it alone.
ok thanks for the input ill see if any1 else has a view aswell, currently i plan to richen slightly about 1/4 max i think should do it i have never run in an hour long main before max has every been was 40 minutes i wonder can i concentrate that hard for an hour lol thanks anyway.
Adam
Adam
what motor/pipe and fuel are you running? i only get about 8 mins out of my tank.
Adam
Adam
o yeh ment 1/4 of a turn, as for engine etc
novarossi p5xs, rb no.6 plug ,hong nor long life silver clutch shoes 1mm springs, 14t clutch bell, and hongnor jp3 fuel is byron 25% gen2 (normal not race blend) o and 8mm carb insert
anyway just done a full strip down rebuild of diffs shocks bearings cleaning checking parts etc for tmoz now time to sleep.
thanks
Adam
thanks
Adam
