Old 08-28-2008, 01:14 AM   #1
tyhodge07's Avatar
Default Kyosho MP9
This is the Kyosho Inferno MP9 Competition 1/8th Off Road Buggy kit. The first all-new design since the introduction of the MP5, it's got a number of features that will ensure ultimate performance. The engine has been moved farther forward for better balance – a concept that first started with the Inferno 777 MP1. This allows much more aggressive performance, but unlike the MP1, the suspension geometry of the MP9 has been fully optimized through years of rigorous testing to take full advantage of the forward weight distribution. The suspension mounts feature captured hinge pins, as does the rest of the car, and changes to the suspension geometry are possible by simply repositioning the inserts without the need to change any parts. A new wing is mounted lower and features large reinforcing ribs to make the wing more durable. The wing no longer uses clips to hold it in place – it's securely bolted to the wing mount.
The Big Bore shocks are standard equipment on this new machine. Additionally, the shocks will also include a special "Velvet" coating that ensures the smoothest operation of the shocks, and they're mounted as low as possible to minimize the center of gravity. The shocks are also mounted to new shock towers.
The drivetrain of the MP9 has been completely optimized, reducing mass wherever possible, and making it more robust in other areas. The differential outdrives have been milled and cross-drilled to reduce weight without compromising durability. Super-lightweight chromoly steel driveshafts, previously available as an option, are also standard on the MP9, but even these have been modified to move the pivot point nearest to the center of the wheel. Unique wheels have even been developed for the MP9, which offer all the strength of a dish wheel, but feature holes large enough to prevent dirt from being trapped on the inside the wheel so optimum balance is maintained.
The overall weight of the car has been reduced by hundreds of grams. The reduced weight makes the car much more responsive, allowing higher speeds throughout the corners and it is more nimble through the bumps and jumps. A significant amount of the weight low reportedly comes from the drivetrain, which has a profoundly positive impact on acceleration.
There are many more updates to the MP9, but based on available information this car is shaping up to be a leader in the class. It's been developed extensively and every aspect of the chassis and drivetrain has been optimized to reduce weight and increase performance, all while maintaining Kyosho's legendary durability.
Features
New castor blocks with castor changing inserts
New hinge pin blocks with interchangeable inserts for toe/kick up
Adjustable track width
New champagne coloured, velvet coating on big bore shocks
New lighter thinner cvd drive shafts
New larger side guards with integrated fuel line routing
Lower engine mount and lower servo positions
Revised fuel tank with integrated fuel lid puller
New chassis braces
New smaller, lighter diffs
Integrated mud guards on rear wishbones
Hex driver hardware throughtout
New retro look wheels
Price: $849.99
Source: Kyosho.com
Due October 2008
tyhodge07 is offline   Reply With Quote
Old 08-28-2008, 05:36 AM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
http://www.rctech.net/forum/nitro-of...p9-thread.html
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Inferno MP9 thread captain america Nitro Off-Road 20015 05-19-2017 02:14 AM
2009 FEMCA 1/8th Offroad Buggy Championship - 23rd-26th July Danny Teh Malaysian R/C Racers 329 08-08-2009 11:54 AM
Kyosho st-rr and mp9 research.. didrace Nitro Off-Road 26 03-20-2009 12:33 PM
Kyosho MP9 Almost New-> Just Under a Gallon jsmax R/C Items: For Sale/Trade 17 03-03-2009 04:47 PM
Used Kyosho Inferno MP9 for SALE!!! TeamX151 R/C Items: For Sale/Trade 19 01-12-2009 07:13 PM
