Old 08-27-2008, 06:14 AM   #1
Trader Rating: 2 (75%+)
Default dry set up for a AD2.
looking for a dry set up. track is rough with big air, need alot of foward bite. dry dusty clay.
i am not happy with the diff, so i will be going through it.
i am going to try a set of clay switches, new set of hole shots, and any other tire that may help. i will be racing it indoor this winter so it will help to get a good jump.
i have 2 truck's one with a TQ chassi and the other is stock.
thanks in a advance.
bill
NOS2stage is offline   Reply With Quote
Old 08-27-2008, 08:45 AM   #2
gubbs3's Avatar
This is what I ran at our last race to TQ on a very slick dry/dusty track. Its basically the same as the Dirt setup off Losi's website with a few changes:
TQ chassis
Add 1/4 ounce lead inside the front bulkhead
Add 3/4 or 1 ounce lead inside the battery box
Don't use any pro-squat shims
Orange pistons in the rear shocks
Losi "bulkhead" or "short neck" ball studs for the front inner studs with one washer(these have a shorter neck which lowers the roll center)
Front end- 1 degree camber, .5 degree toe out.
I ran Losi red directionals and J Concepts green double dees for tires when it was dry. Red ifmar pins when wet.
gubbs3 is offline   Reply With Quote
XXX-NT AD2 Thread DemonLosi Nitro Off-Road 2245 06-06-2017 01:16 PM
A different way to up grade to AD2 fastandclean Electric Off-Road 14 05-09-2005 05:27 PM
