Old 08-26-2008, 04:33 PM   #1
iLL-Mitch's Avatar
Default MBX5T Front and Rear drive shafts
This weekend i bent my 3rd drive shaft on my mugen truggy. its the second LF in 3 months. I have not collisions and no big crashes during my race. Has anyone else had this problem and if so what have you done to not have this happen again. It did not effect the handling( i was still able to get a win) but i am very curious as to what going on. Mugen said its normal for the type of tracks in Nor Cal but i have not heard of other brands having this issue. If anyone has any input i would like to hear it. Thank you.
iLL-Mitch is offline   Reply With Quote
Old 08-26-2008, 05:50 PM   #2
stump27's Avatar
make sure your pivot balls are not screwed into the arms too far in the front. that could cause the axle pins to jam into the drive cups and bend them. no, i haven't had this problem. just make sure your drive cups don't have too much wear, that causes broken shafts when the suspension goes through the full range of motion on power.....
stump27 is offline   Reply With Quote
Old 08-26-2008, 07:09 PM   #3
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I beleive also the plastic bushings for the arms can cause this. They get loose and flex under stress. I prefer the brass bushing inserts and aluminum upper H/L mounts. Keeps the suspension more in check without any play or flexing during use.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-27-2008, 06:15 AM   #4
iLL-Mitch's Avatar
who makes the upper H/l mounts in Alum. ? thanks for the info... I will look at everything again....
Old 08-27-2008, 06:17 AM   #5
cbaranski's Avatar
Trader Rating: 43 (100%+)
iLL-Mitch,
I run the King Headz H/L upper arm holders
Chuck
Chuck Baranski www,pikemotorsportsrc.com
Xfactory SCX60CF w/ 12mm BB, Tekin RSX, Tekin RPM 17.5, Savox 1258
AE B5M FT, Tekin RS, Tekin RPM 17.5, Savox 1258tg
cbaranski is offline   Reply With Quote
***MUGEN MBX5T ROLLER*** jpalessi R/C Items: For Sale/Trade 58 09-08-2009 01:40 PM
FS: Custom T-MAXX pics gunmax R/C Items: For Sale/Trade 16 03-12-2009 11:14 PM
MBX5T Clean Up TStorm Nitro Off-Road 6 11-25-2008 09:04 PM
mugen mbx5t prospec Jammin57 R/C Items: For Sale/Trade 7 04-25-2008 04:38 PM
Mugen MBX5 Parts Lot TStorm R/C Items: For Sale/Trade 9 04-07-2008 10:21 AM
