Old 08-25-2008, 10:52 AM   #1
PinoyCali's Avatar
Default Need help!!!broken screw on crankcase
Hello..
What kind of tool you guys use to pull out the broken hex screw on crank case? Right now the engine have 3 hex screws at the back plate. Is this gonna be a problem for airleak or just use sealent?
Thanks..
PinoyCali is offline   Reply With Quote
Old 08-25-2008, 11:25 AM   #2
dont fully understand where or in what way the screw is stuck? any pics?
has the head just rounded of ir is it snapped of?
if just rounded you could cut a line in it and use flat head screw driver if broke could you not just remove other screws then use grips or somthing to remove whats left of the screw.
adz06 is offline   Reply With Quote
Old 08-25-2008, 11:29 AM   #3
PinoyCali's Avatar
the hex screw snapped. Im afraid if I use drill I will damaged the crankcase.
Old 08-25-2008, 11:45 AM   #4
you must be strong lol
its the backplate i take it then could you not remove the 3 current screws and slide of the backplate cover as the backplate isnt actually threaded its the bracnkcase so you should be able to in theory slide of the backplate and then use grips to remove whats left of the screw.
Old 08-25-2008, 11:51 AM   #5
if the above method does not work, you can try using a reverse drill bit...
AVID Bearings- The best bearings hands down
Upgrade-RC- Keeps the bling going
BCE Speed- Holds it down
Tonys Screws- Keeps you from getting screwed
Byrons Fuel- Makes the RC world go round
Jesse is offline   Reply With Quote
Old 08-25-2008, 12:13 PM   #6
PinoyCali's Avatar
Thanks guys i will give it a shot. Or else use 3 hex screws and a sealant. Im just thinking about the airleaks w/o the 4th screw.
Old 08-26-2008, 06:26 PM   #7
Default Boaters posted this another sight
Water cools the heads in boat motors and if you don't use oil in there after they break off sometimes.
Seen posted several times to use sulfuric acid "....soak the block only...." will disolve steel screw not hurt aluminium.heard it takes three days. Do not use hydracloric type muric ect... You could soak some old alum rc part and a screw first to see if it's true.
Extreme precautions no kids ,,,google ect...
Of coarse FIRST I would soak it in kroil and try pencil toarch at the case screw area alum expands more then steel . Then use a drywall screw as a punch to chisel the screw carfully around at about 45% angle close to outside of the screw at any possible edge the break might of left me. Slight impacts loosen all kinds of things if you use pataincence.
GOOD LUCK
153stars is offline   Reply With Quote
Old 08-26-2008, 08:08 PM   #8
Trader Rating: 5 (86%+)
I've been running with only 3 screws at the backplate for 4 gallons on my Nova, no issues at all Although it is uncomfortable to know about it.....
FM 75.710
razor_clawzz is offline   Reply With Quote
Old 08-26-2008, 08:26 PM   #9
lorinser999's Avatar
Default Same
Originally Posted by razor_clawzz View Post
I've been running with only 3 screws at the backplate for 4 gallons on my Nova, no issues at all Although is is uncomfortable to know about it.....
Same with me,runnin 3 screws at the back plate,very uncomfy!need to check at least after tanks but then no leakin
lorinser999 is offline   Reply With Quote
Old 08-27-2008, 08:29 AM   #10
PinoyCali's Avatar
Thanks all
WTB Novarossi Plus 21-5 crankcase yourtxlender R/C Items: Wanted to Buy 1 07-07-2008 08:06 PM
WTB WS7 II crankcase rcdude69 R/C Items: Wanted to Buy 0 02-22-2008 08:26 PM
WTB: O.S. .21 RZ CRANKCASE!!!! jon-brady R/C Items: Wanted to Buy 0 07-30-2007 10:38 PM
WTB : OS .21 RZ crankcase Ed Pasoquen R/C Items: Wanted to Buy 2 10-29-2006 03:46 PM
taking out broken diff screw KoE Rookie Zone 3 04-14-2004 07:43 AM
