Old 08-24-2008, 05:12 PM   #1
Default OS V-Spec won't idle
I've got a pretty good tune on my OS V-Spec. Still trying to get more bottom end out of the corners. However I can't get it to idle without the car moving. I imaging it's because the crankshaft is spinning the clutch shoes fast enough for them to rotate the clutch bell... I guess. Any thoughts and help on getting it to idle without my RC8 moving?
Thanks,
Pete
Captpete is offline   Reply With Quote
Old 08-24-2008, 05:17 PM   #2
jrwoodchuck's Avatar
I'm sure it has something to do with idel screw in too much, but low end mixture also plays a part, and you can't forget about the clutch. What spring/shoes are you running? It's also possible to have a broken spring and it's letting a shoe is hitting the bell. It's going to be one of thoes three things.
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 08-24-2008, 05:33 PM   #3
Gliptal's Avatar
My guess would be LSN too rich and idle screw in too far, basically what Woodchuck said.
If that is the case check your HSN, its probably too lean.
Gliptal is offline   Reply With Quote
Old 08-24-2008, 05:33 PM   #4
josh35's Avatar
If the car won't sit still and idle check your clutch because if it is hanging up or if the bearing s are are bad it cause the problem
josh35 is offline   Reply With Quote
Old 08-24-2008, 05:35 PM   #5
I just checked the clutch and springs. I'm running the clutch and springs that came with the RC8. Aluminum Shoes. Springs are all okay. Just checked them. I've heard some people open up the low end needle a lot then turn out the idle screw to get it to idle. I was just wondering if I should be running different shoes.
Old 08-24-2008, 05:36 PM   #6
Bearings are good. I've only gotten about a gallon through the engine so far.
Old 08-24-2008, 05:39 PM   #7
I would set the idel screw back to factory. It works fine, I've never touched one on any of my OS motors. Then tune for that.
Doug
TLR 22/M-11
Old 08-24-2008, 05:40 PM   #8
okay I'll give that a shot tomorrow night.
Old 08-25-2008, 02:03 AM   #9
lowey79's Avatar
How do ya get them to idle during break in with the factory settings?
lowey79 is offline   Reply With Quote
Old 08-25-2008, 08:01 AM   #10
Just keep working the throttle, every 2 or 3 seconds pull trigger to 1/4 throttle, then off. Also my glow driver wont stay on the turbo plugs. So just work the throttle...
Doug
TLR 22/M-11
Old 08-25-2008, 01:59 PM   #11
Okay dumb question alert guys.
When idling should you have the break on? If so then I'm not having a problem then. It's sitting nicely with the breaks on idling.
Pete
Old 08-25-2008, 02:50 PM   #12
t0adman's Avatar
No, you shoudn't have to keep the brakes on to idle without moving. How would you describe the idling? Does it seem to be revving pretty high or quieter and slower? A video would be helpful.
t0adman is offline   Reply With Quote
Old 08-25-2008, 03:10 PM   #13
I'll get a video tonight and post it. Today I tried raising the lsn a half turn from flush and lowering the idle screw. It won't start in those positions. If I back them off a bit I can get it to start, the engine runs very slow and the wheels are spinning slowly while the buggy is sitting on the start box. As soon as I place it on the ground it stalls out.
Pete
Old 08-25-2008, 03:19 PM   #14
t0adman's Avatar
Did you check to make sure the clutch bell spins nice and smoothly when it's mounted correctly? It sounds to me like something in the clutch assembly is hanging. Bad or too many washers/shims, bearings or hanging shoes could all do it.
Old 08-25-2008, 04:43 PM   #15
Here's video of it running sitting on the starter box. I can get it to run a little slower than this with the LSN at 1 o'clock from flush, and the idle screw at about 8 o'clock from factory default. I'll take the clutch assembly apart and take a picture of it. Bell spins nice and smooth.
Couldn't get the file small enough with Winzip. I uploaded to youtube.
http://www.youtube.com/watch?v=-w9bHcJhkZs
Pete
V-ONE S Thread rhandee Nitro On-Road 4584 07-06-2014 06:19 PM
Blew up new o.s. motor CorallyBQuiK Electric Off-Road 11 03-21-2006 02:10 PM
