Old 08-23-2008, 05:07 PM   #1
Default Will the Clutch Bell wear more running an RC8 on Grass?
I was wondering if running on grass where there's more resistance if that would cause the clutch bell teeth to wear more than running on dirt or pavement?
Thanks,
Pete
Captpete is offline   Reply With Quote
Old 08-23-2008, 05:26 PM   #2
Trader Rating: 27 (100%+)
I wouldn't think that alone would make it wear faster. But if you notice the higher drag of the grass making your clutch slip more, the heat buildup I suppose could wear it out. A proper gear mesh is what will make the teeth last a long time.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 08-23-2008, 05:29 PM   #3
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
Thanks,
Pete
Yeah the whole clutch should wear more, but I would check your gear mesh.. An improper mesh setting will cause excessive wear.
When setting your mesh try to get the engine as straight a possible from front to back, Also I rip a piece of business card and sandwich it in between the gears to get a correct mesh setting.. tighten up your engine and pull the paper out.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-23-2008, 06:37 PM   #4
Grass provides much more traction than dirt or even asphalt, so I have to imagine it's putting much more stress on the entire drivetrain. Yes, check the gear mesh to be sure it's set properly, but I would expect more wear in the drivetrain regardless.
rcg33k is offline   Reply With Quote
Old 08-23-2008, 07:16 PM   #5
jpalessi's Avatar
+1
Joe Alessi
www.Lucky7RC.com
Old 08-24-2008, 04:42 PM   #6
IanWright's Avatar
Location: If i'm not in England i'm in Southern California
Send a message via AIM to IanWright
I have raced on grass a few times and yes it does wear on the drivetrain a lot, brakes and where tires meet rims.
IanWright is offline   Reply With Quote
Running on Short Grass - how bad for xxx-t? HoaRC Rookie Zone 33 06-26-2008 01:33 PM
Shim between inner clutch bell and clutch shoes razor_clawzz Nitro Off-Road 8 02-03-2008 09:24 PM
New kyosho flywheel and clutch bell plus 2 unopend clutch shooes tlxxx4driver R/C Items: For Sale/Trade 0 07-17-2007 02:54 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
