Old 08-23-2008, 07:19 AM   #1
gsxrmcs's Avatar
Send a message via AIM to gsxrmcs
Questions?? nitro rustler throttle response problem
i have a nitro rustler and for some reason when i start it up cold it runs fine then when it heats up it has no power on the bottom end but then when it gets going a little (top end) it takes off like crazy what would make this happen and how can i fix it. if any one has any ideas please let me know thank you
gsxrmcs is offline   Reply With Quote
Old 08-23-2008, 07:27 AM   #2
try this link with lots of possibilities
Model feels sluggish (poor acceleration)
http://www.traxxas.com/support/kb_se...&cat=112&id=22
or this one
http://www.traxxas.com/support/kb_se...cat=112&id=104
chongo is offline   Reply With Quote
Old 08-23-2008, 07:34 AM   #3
gsxrmcs's Avatar
Default rustler
i am sorry it not that i just doesn't go fas it sounds like the motor is bouging down and it does that for a little then it takes off i think something is not tunned right but i am new to the rc world and i am not sure what is not tunned and the best way to fix it
Old 08-23-2008, 07:38 AM   #4
wingracer's Avatar
Trader Rating: 23 (100%+)
Most likely it's a little lean. Run it and when it starts to get sluggish richen it up a bit and see if it improves. You might need to richen the low end needle a bit too.
Also it could be overheating.
Clutch problems could cause this as well.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-23-2008, 12:59 PM   #5
gsxrmcs's Avatar
i was just running it to try to tune it to get it to stop the hesitation and now it just shuts off sometimes when i get on it and other times when i get off the throttle now what could be wrong with it
Old 08-24-2008, 08:25 AM   #6
I would reset the needles back to factory and start tuning all over.
High speed needle 4 turns out from closed
Low speed needle flush or 1.5-1.75 turns out from closed
Idle gap (slide valve) .7mm-1mm
http://www.traxxas.com/support/kb_se...5%20break%20in
Old 08-24-2008, 12:23 PM   #7
gsxrmcs's Avatar
yea i guess that is what i am going to do just start from stock settings
nitro rustler problem gsxrmcs Nitro Off-Road 4 08-03-2008 03:47 PM
Nitro Rustler motor problem dieseldog20 Nitro Off-Road 12 03-08-2008 12:36 AM
Question about on throttle response. Nuclear Dave Electric On-Road 6 01-24-2008 06:37 PM
Need help with M8 throttle problem Jerrit1 Nitro On-Road 1 08-20-2007 03:00 AM
M8 throttle problem Jerrit1 Nitro Off-Road 1 08-20-2007 12:17 AM
