Old 08-21-2008, 07:58 PM   #1
sullen909's Avatar
Default Losi XXX-NT Diff question
I hope this is in the right forum.
Anyways i have been having problems with the diff in my xxx-nt. I think either the diff screw or the nut might be stripped. I tightened the diff and was able to drive for about 5 minutes. Than the diff got loose and started slipping. I have done this twice
My question is this. Can I take the diff screw out without taking apart the transmission. Or Do I need to pull the whole thing apart.
My 2nd question
Does anyone have a spare xxx-nt transmission lying around? id pay a reasonable price.
sullen909 is offline   Reply With Quote
Old 08-21-2008, 09:01 PM   #2
Trader Rating: 2 (75%+)
u can change the diff screw with out pulling the trans apart.
i may sell a spare trans, i have to decide if i am going to sell a extra truck we have. all sepends on what u are looking to spend.
NOS2stage is offline   Reply With Quote
Old 08-21-2008, 09:06 PM   #3
CaseyP's Avatar
Make sure to use a new losi diff nut. They don't work so well the second time around
CaseyP is offline   Reply With Quote
Old 08-21-2008, 09:43 PM   #4
sullen909's Avatar
Yeah I rebuilt it because the diff gear was worn. I priced out all the parts for a new trans and it was around 85 dollars. I saw a roller losi on craiglist for 75 but it got snatched up. The reason i want a whole new transmission is that I dont know what else is damaged in the trans. My dad did some donuts and its never been the same since.
Old 08-22-2008, 06:04 AM   #5
i have a rtr. with aluminum front and rear arms and front shock tower, i set of tires with no bodie. i sell that for 65 shiped. roller only
Old 08-22-2008, 03:27 PM   #6
shawnp.'s Avatar
i would tear it apart and just replace the diff gear and diff balls and idler gear and thrust bearings get a new diff screw it is probably less than 25 dollars the rest of the bearings in the transmission are probably good losi parts house has everything you need really cheap
shawnp. is offline   Reply With Quote
Old 08-22-2008, 06:01 PM   #7
Trader Rating: 14 (100%+)
why dont you check to see if you have the diff bolt in backwards. If it is backwards, the diff will loosen up when running. As far as the diff nut, i re-use mine all the time. I change my rings every other rebuild.
o.s. power is offline   Reply With Quote
Old 08-23-2008, 02:32 AM   #8
sullen909's Avatar
Yeah got it apart, the nut was stripped. The diff screw isnt though. Im just going to buy the diff adjustment set. Hopefully after that I can get it to the track
Old 08-24-2008, 02:09 PM   #9
get the new bolt that comes with the spring instead of using those dumb belleville washers. Diff is alot easier to adjust too.
Old 08-24-2008, 03:51 PM   #10
sullen909's Avatar
most definitely, and Im glad they changed the thrust bearing design also.
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1710 08-26-2015 04:39 PM
Losi XXX-S TSR6 Electric On-Road 14329 01-26-2015 07:59 PM
Losi xxx-4 Chrissy C Electric Off-Road 2902 05-26-2011 09:10 AM
new Team Losi Speed-T rtr samiel2d Electric Off-Road 40 07-25-2010 08:20 PM
Losi Off-road!!! Speedo Electric Off-Road 326 11-12-2003 10:15 AM
End Of Year Sell Off!~~~~~~~~~~~~~~~ P R/C Items: For Sale/Trade 6 11-02-2003 10:38 PM
Front spool, over and under drive tricklosi Electric On-Road 7 08-16-2003 09:33 PM
