Old 08-20-2008, 11:06 PM   #1
TC3ElectricGuy's Avatar
Default Carb Restrictor
Who here races with a carb restrictor on their intake.
I"ve done a bit of reading and a few searches and found that they slow down the engine thats already overpowered, and increase run time. Also to richen out the needles if removing it from the carb.
What are peoples opinions here in regards to these.
Do you use one?
What benefits do you think there is to taking it off or leaving it on.
TC3ElectricGuy is offline   Reply With Quote
Old 08-21-2008, 07:29 AM   #2
I know that engines from Sirio, novarossi and OS use carb restrictors. They all use a carb restrictor at all times and can be easily swapped out as a tuning option. A smaller restrictor opening will decrease your top speed and may affect the bottom end slightly or maybe not at all. You will however gain runtime.
Genius is offline   Reply With Quote
Old 08-21-2008, 07:44 AM   #3
wingracer's Avatar
Trader Rating: 23 (100%+)
I often run them in on road for more run time (8.5mm or 8mm).
Since all the off road tracks around here are small and tight I see no reason not to use at least an 8mm and usually a 7mm. If you can't use all that power you might as well get better mileage.
I have on occasion seen motors that were very difficult to get tuned right on the bottom end and dropping to a smaller venturi cleared out the problem and made them much more tune friendly.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-21-2008, 10:11 AM   #4
Trader Rating: 21 (100%+)
Default venturi
I have a .28 in my truggy and the insane power hurt my lap times. I went to a 6.5 and now a 6mm venturi. I can still clear the biggest jump on the track and have now gained almost 2 minutes run time.
WALZ is offline   Reply With Quote
Old 08-21-2008, 11:11 AM   #5
skeller's Avatar
Send a message via AIM to skeller Send a message via MSN to skeller Send a message via Yahoo to skeller
If you wanna seriously increase your runtimes but don't want to loose much...if any noticable power....I strongly recommend IDRC carb inserts. If your racing....they are a must have item. I run a 6mm in a Go tech 5P and can pull a 10min run pretty easy.
skeller is offline   Reply With Quote
Old 08-21-2008, 12:50 PM   #6
I am sure the 15 inches of fuel line help also......
brian kadow is offline   Reply With Quote
Old 08-21-2008, 12:59 PM   #7
Brian are you picking on the short "gifted" people
katjim00 is offline   Reply With Quote
Old 08-21-2008, 01:22 PM   #8
skeller's Avatar
It's legal.....I promise.
I just got off the phone with your boss......
Old 08-21-2008, 02:22 PM   #9
Ralph Walters's Avatar
Hello all,
The IDRC Velocity Venturi's were designed with the racer in mind. They will improve overall performance and mileage of the engine without killing the top end power.
You can run a 6 or 7mm IDRC venturi and increase low to mid response and still acheive the same top end power that you would with a stock OEM 8mm venturi.
The power the engine produces will be smoother through the entire powerband and fuel mileage will increase due to a broader powerband.
These venturi's work very well and are unlike any other on the market.
Innovative Designs Racing Concepts
Ralph Walters is offline   Reply With Quote
Old 08-21-2008, 02:36 PM   #10
skeller's Avatar
Originally Posted by Ralph Walters View Post
Hello all,
Uhhh....ya. They are the best!
Old 08-26-2008, 09:45 PM   #11
Send a message via AIM to Twotan
i run a 6.5 mm carb restrictor in my nov 821b on my x2 and it has plenty of power.
Twotan is offline   Reply With Quote
Old 09-28-2008, 02:25 AM   #12
I am looking for 5.5 or 6 carb restrictor for the OS Speed or are they any which fit the OS?
joydude630 is offline   Reply With Quote
Old 09-28-2008, 09:33 AM   #13
yup. I run an OS 5.5mm in my jx .21. It is an actual OS part. Machined metal and not plastic. Really tames this motor. Can't remember the part #.
Mugen MBX7R Eco
SC5M
Mugen MBX7R Werks B6/2 Pro
Futaba 3PKS
maximuspowell is offline   Reply With Quote
Old 09-28-2008, 09:39 AM   #14
slakr's Avatar
Trader Rating: 28 (100%+)
where can i purchase carb restrictors?
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 09-28-2008, 09:51 AM   #15
skeller's Avatar
Ralph Walters @ IDRC
rwalters163@msn.com,
Official Go Engines Thread MassiveMods Australian Racing 1862 02-13-2012 04:44 AM
racing and fuel milege aside. What is the most powerfull engine you can put in a dreaux Nitro Off-Road 51 07-11-2009 04:46 PM
Engine Tuning tips from you motor experts jsmax Nitro Off-Road 13 02-15-2009 07:30 PM
k&n air filter mrredrsx02 Nitro On-Road 88 12-21-2003 10:12 AM
