Old 08-18-2008, 06:40 PM   #1
brofroe's Avatar
Trader Rating: 20 (100%+)
Default BENT SHOCK SHAFTS
I KEEP BENDING REAR SHOCK SHAFTS ON MY THUNDER TIGER EB-4 S2 PRO BUGGY. I THOUGHT MAYBE I WAS USING TOO THICK OF SHOCK OIL FOR BIG JUMPS(TOO MUCH PACKING UP), SO I WENT FROM 30W TO 22.5 W. STILL BENT ONE. ANY HELP IS APPRECIATED.
brofroe is offline   Reply With Quote
Old 08-18-2008, 06:44 PM   #2
Trying not to sounds bad but...
Don't crash.
I really don't think it has to do with setup. You can get some rear guards.
Don Duct is offline   Reply With Quote
Old 08-18-2008, 07:00 PM   #3
brofroe's Avatar
are you saying something is coming in from behind and bending them in a crash? other than that i don't see how a crash is any more abusive than landing hard(incorrectly) from 8+ ft.
Old 08-18-2008, 08:00 PM   #4
Unless they are binding and not moving smoothly I don't see how normal compression of a shock in any normal setup would bend the sharft.
Only thing I can suggest is to check your shocks after each race to make sure they are not binding and flush dirt out of the o-rings with shock oil. To do this put oil on the shaft then compress the shock driving the oil in to the o-ring. This will flush dirt out.
Also one common mistake is to over tighten the nut on the shock tower. This will cause the shock to bind. The nut should be a self locking nut and loose allowing the shock to pivot freely.
Old 08-18-2008, 08:12 PM   #5
brofroe's Avatar
THANKS FOR TIPS MAN. ANY OTHER ADVICE IS APPRECIATED.
Old 08-18-2008, 08:19 PM   #6
wes95_z28's Avatar
Its an 8+ pound buggy with toothpicks for shockshafts. Try to get some different shocks that have 3.5 mm shock shafts.
Thunder tiger kinda went skimpy in the durability department on that buggy.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 08-18-2008, 09:41 PM   #7
I guess the other cause could be toothpick shafts. Honestly I don't know much about this particular kit.
Old 08-19-2008, 11:10 AM   #8
brofroe's Avatar
I THINK 3MM IS A LITTLE BIGGER THAN A TOOTHPICK. I BELIEVE IT MAY BE OVERTORQUING OF THE TOP NUT AS MENTIONED ABOVE.
Grande Prairie Model Racers Association WheelNut Canadian R/C Scene 19805 06-10-2017 01:40 PM
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 08:40 PM
8T 2.0 polarismaster Nitro Off-Road 15880 02-02-2015 10:31 AM
Yokomo MR4-BX Worlds Ed. SammyZ Australia For Sale/Trade 16 06-23-2009 07:54 AM
Integy shocks for the Savage crash21 Monster Trucks 34 03-10-2006 03:09 PM
What is the most bulletproof trouble free TC? Cmotif Electric On-Road 44 05-02-2004 09:26 AM
