Old 08-18-2008, 10:09 AM   #1
Akhor's Avatar
Default Optimal Exhaust Tubing Length
This past weekend I was out racing and my exhaust tubing was cut. Since I only lost about one inch I just plugged it in and kept going. However this drastically richened up my tune.
What is the optimal length of the exhaust tubing from gas tank to exhaust for a 8ight?
OR does it really matter as long as the tune is bang on?
Akhor is offline   Reply With Quote
Old 08-18-2008, 07:41 PM   #2
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
There is no real ideal length. Since you tuned the engine with a specific length of hose and then had to cut off an inch, it would richen up and you would have to retune. Same goes for adding more pressure hose, it would lean out mostly in the midrange. One idea would be to measure your hoses and record the lengths. If you need to replace them and you run the same lengths and type hose, your tune should not change. I have seen more issues from running too long of a hose than shorter hose.
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-18-2008, 07:48 PM   #3
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Great thread and a topic I think I and most others don't note or recognize this as evening a possible issue.?
I'm going to document mine before I forget.
UN4RACING is offline   Reply With Quote
10.5 brushless optimal gear ratio shadowless Electric On-Road 1 07-15-2008 08:06 PM
Return fuel tubing length - how to lower pressure in tank charlesd Onroad Nitro Engine Zone 3 06-13-2008 10:32 PM
Exhaust tip length gearhead13 Onroad Nitro Engine Zone 0 07-28-2006 01:08 PM
optimal temperature for soldering John_S Electric On-Road 2 06-15-2005 02:29 PM
exhaust stinger length jason102276 Nitro On-Road 11 05-04-2003 04:50 AM
