Old 08-16-2008, 12:18 PM   #1
nsgland's Avatar
Trader Rating: 19 (100%+)
Default Grease
What type of grease is used for the wheel bearings and clutch bearings. Red,Black,Mobile 1,10w30 oil..??? Also when replacing wheel bearings should you go with rubber/metal shielded bearings or rubber on both sides?
Neil
NSG Racing
Tamiya TA05 V2
Futaba,Tekin,Savox,LRP,Exotek,Sorex,Alpha
CapeFearRaceway.com
nsgland is offline   Reply With Quote
Old 08-16-2008, 08:27 PM   #2
nsgland's Avatar
NSG Racing
Tamiya TA05 V2
CapeFearRaceway.com
Old 08-16-2008, 08:38 PM   #3
imaxx21's Avatar
Send a message via AIM to imaxx21
at $1 each, its not really worth it to worry about greasing them IMO
just replace with new..
an awesome bearing company to check out is www.readyrollers.com
he sells kits for cars, or just sleeves of wheel and clutch bearings..
and rubber/metal i the way to go
-Crash
Upgrade RC www.upgrade-rc.com
imaxx21 is offline   Reply With Quote
Old 08-16-2008, 08:51 PM   #4
2005 crf 450's Avatar
Neil
I dont think its 10w30 oil, thats the kind of oil I put in the tranny and clutch of my dirtbike. Its an oil not a grease.
and yeah, I wouldnt even worry about greasing the clutch bearings, not worth it. I use Losi Green Goo grease and it seems to work pretty good.
2005 crf 450 is offline   Reply With Quote
Old 08-17-2008, 06:50 AM   #5
nsgland's Avatar
Default Avid
This is what I saw on Avids website.
What should I use to lube my bearings?
There is honestly nothing better on the market that we have found as far as bearing oil other than 10w30 Mobil 1 car oil. The oil is highly engineered and designed for high temperature situations, and a quart will last you your lifetime in RC.
http://www.avidrc.com/shop/?action=support#clean
NSG Racing
Tamiya TA05 V2
CapeFearRaceway.com
Old 08-17-2008, 01:30 PM   #6
Jaz240's Avatar
Trader Rating: 52 (100%+)
Oh man I thought this was "Grease" the movie!
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-17-2008, 01:37 PM   #7
nsgland
Avid sells some really good quality bearings. If you use the mobil 1 like David says they will spin free all day long. Bearings require more maintainance with oil in them is the only drawback. I run the TKO ceramics and I use Eureka lube in them, they spin like sin and require a little less maintainance than bearings with oil. I figure they will last at least a complete season with care so it averages out like buying 18 of the $1 bearing ones 4 times a season.
katjim00 is offline   Reply With Quote
Old 08-17-2008, 01:49 PM   #8
nsgland's Avatar
Originally Posted by katjim00 View Post
nsgland
Where can I get Eureka Lube? Who makes it?
Thanks,
Neil
NSG Racing
Tamiya TA05 V2
CapeFearRaceway.com
Old 08-17-2008, 01:59 PM   #9
imaxx21's Avatar
http://www.rccompound.com/ProductDet...tCode=TKO-El-1
-Crash
Old 08-17-2008, 02:05 PM   #10
Peter sells it at TKO as well as bearings. If you are in the states that is another place to buy it. His website is www.tkocompetitiondev.com.
Old 08-17-2008, 02:24 PM   #11
hmm, I guess thats right, it is a high quality oil, it is made for extremely high temps, and a 3$ quart of oil will last literally a lifetime.
I dont know how hot clutch bearings get, but maybe a w20 oil would be a bit better? w40 is for extreme temps, w30 is for medium, maybe a 5w20 would be the best?
Old 08-17-2008, 02:25 PM   #12
imaxx21's Avatar
most people blow the grease/oil out of their clutch bearings before they put them in....
they'll spin freer and wont get oil on your shoes..
-Crash
Old 08-18-2008, 11:30 AM   #13
nsgland's Avatar
would GMK Mobile 1 be ok to use on wheel bearings? I have a small tube of that.
NSG Racing
Tamiya TA05 V2
CapeFearRaceway.com
Do you grease your gears? chin Singapore R/C Racers 8 02-18-2008 05:46 AM
grease... n3rd420 Rookie Zone 7 05-29-2006 05:10 PM
Tamiya Anti wear Grease or Ceramic Grease..?? TRFTIM Nitro On-Road 6 04-24-2006 10:52 AM
Silicone Diff grease, Axle thrust grease holycow Electric On-Road 3 10-25-2003 10:33 AM
Grease, which is which ?? Wolf Electric On-Road 9 09-25-2002 03:56 AM
