Old 08-11-2008, 10:24 PM   #1
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Default Clear coat/protective coating for lexan paint job?
Is there good clear coats or protective coatings for use on polycarb bodies? I've heard some people using shoe goo, but I'd rather spray. I'd like an aresol can!!!!!!!
rallyebmx is offline   Reply With Quote
Old 08-11-2008, 11:37 PM   #2
wenotlast's Avatar
i use 3m rubberized under coating. lasts forever and helps keep the body from wearing out quick. just make sure you back you finished paint job in a silver or a white before you spray it
hyper 8.5 pro
trinity moster horepower fuel
GO tech .21 5port turbo
In Loving Memory of Braxton Lee Harville 2/22-3/30/07
wenotlast is offline   Reply With Quote
Old 08-12-2008, 04:53 AM   #3
Trader Rating: 36 (100%+)
http://www.rustoleum.com/CBGProduct.asp?pid=166
DIALED!
NitroOB4You is offline   Reply With Quote
Old 08-12-2008, 05:59 AM   #4
slaytanic's Avatar
Trader Rating: 20 (95%+)
Rustoleum
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 08-12-2008, 06:49 AM   #5
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
This actually sounds like a good idea. We do a couple of things:
Where the body pin holes go, we put some of that woven fiberglass drywall tape and some shoe-goo. (or "small job liquid nails.) Helps prevent cracking!
On areas that may rub (over the pipe for example) we put clear vinyl tape, or plain ol' electricians tape, or just more shoe-goo, (or "small job liquid nails.") Clear and flexible, and tough. Be sparing in the use... the weight can add up pretty quick.
One thing you DON'T want to use is a "hard" finish because it will crack and peel off, taking your paint job with it... and be careful that the paints are compatible! If not, it will cause some pretty interesting results (cracks with whatever color is behind showing through. I painted a guitar like that once, using that INTENTIONALLY to get the odd finish... Enamel and lacquer don't mix for example. Not sure about the different types of paint for Lexan and other paints...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-12-2008, 06:52 AM   #6
Suspended
That's what Team Kyosho driver Cody King has done for years.
szakcajaru is offline   Reply With Quote
Old 08-12-2008, 07:03 PM   #7
rallyebmx's Avatar
The Rustoleom is flexible enough and is compatible with polycarb paints? The 3m sounds interesting.
Old 08-12-2008, 07:17 PM   #8
UN4RACING's Avatar
Trader Rating: 22 (100%+)
3M and rustoleum. Will they work with water base paint?
UN4RACING is offline   Reply With Quote
Old 08-12-2008, 07:20 PM   #9
David Day's Avatar
Send a message via AIM to David Day Send a message via MSN to David Day Send a message via Yahoo to David Day
Rustoleum sounds more friendly
Day Brothers Racing
*http://daybrosracing.webege.com*
2nd Place 2006 Winter Series 10th/Scale Gas @ Lake Havasu RC Raceway
RC10GT - Snoopy #5x
Kyosho Inferno777 WC SP2
David Day is offline   Reply With Quote
Old 08-12-2008, 08:18 PM   #10
Integra's Avatar
i use permatex high temp silicone and the drywall tape method DOMIT mentioned....but i take it a step further and do the wheel wells and anywhere i know its gonna crack gets a layer of tape and silicone...its a little ugly from the underside...but my shells last me over a season
Old 08-12-2008, 08:44 PM   #11
dethklok151's Avatar
Trader Rating: 64 (100%+)
i have started using modge-podge with good results thus far.it is available at places like micheals craft stores.
"hey buddy,ya gonna finish marshalling my car or just lay there and bleed?"
dethklok151 is offline   Reply With Quote
Old 08-12-2008, 08:49 PM   #12
carlosm's Avatar
Trader Rating: 17 (100%+)
I've been using Krylon "Fusion" Gloss White to seal my paint jobs (all fascolor, or createx water based paints).. seems to hold up prety good.
Carlos Macias
Durango - DNX408, DESC410, DEX210
LutzRC.com - AnswerRC - Kal-Gard - Acendancy Racing - PT RC Silicone's
BuckarooGear.com
carlosm is offline   Reply With Quote
Old 08-12-2008, 08:51 PM   #13
Suspended
....and my bodies weigh 42 lbs. by themselves.
Old 08-13-2008, 06:38 AM   #14
Integra's Avatar
they hold up tho...and its not like its slowing me down.
Old 08-13-2008, 06:43 AM   #15
Suspended
That's true, if you're already slow it's not like you can go slower.
Need Chassis protective Clear film please Wing Chun Electric On-Road 5 03-25-2007 03:00 PM
Clear coating SpeedySST Electric On-Road 3 11-24-2006 04:48 PM
clear coating nikkon99 Electric On-Road 3 08-15-2006 10:11 PM
Question: What can you use for a protective clear coat if... TexasPete Painting, Designs, Graphics and Photography 0 04-28-2005 09:37 PM
Base coat/clear coat racer01 Painting, Designs, Graphics and Photography 1 01-15-2004 03:35 PM
