Old 08-11-2008, 03:25 PM   #1
gsxrmcs's Avatar
Send a message via AIM to gsxrmcs
Questions?? rustler brake question
i have a rustler and for some reason i keep melting the brakes they are set up right i do use them pretty much but should they melt and is there a metal brake or some other brake that would work for the rustler if anyone has any ideas please let me know thanks also for some reason my rear wheels are turned in is the a way to adjust them?
gsxrmcs is offline   Reply With Quote
Old 08-11-2008, 04:28 PM   #2
I have a nitro rustler and have never melted a brake disk.
Your rear wheels should have 3 degree's of toe in.
1) For the brake disc is your slipper adjusted correctly?
2) Is your throttle linkage causing your brake to rub when in neutral or while accelerating?
3) Is your brake linkage dropping in the holes and causing you not to have any brakes?
I use these in mine now and boy does it stop.
Ofna Brake Disk Fiber X1-CR/CRT direct fit. NO DREMELING!
There's 2 fiberglass disc's in the package.
Also for more info try Traxxas web forum LINKY
A wealth of info HERE
chongo is offline   Reply With Quote
Old 08-11-2008, 04:43 PM   #3
gsxrmcs's Avatar
Default brake
1) For the brake disc is your slipper adjusted correctly? yes it is adjusted right
2) Is your throttle linkage causing your brake to rub when in neutral or while accelerating? no no rub
3) Is your brake linkage dropping in the holes and causing you not to have any brakes? no i had a local hobbie shop adust it and it worke fine for a little but then i was running it hard and i lost the brakes when i looked at it the disc was melted away so maybe i will just go with the carbon fiber. do they wear out fast or do they last for a long time
Old 08-11-2008, 09:19 PM   #4
I've had my rustler for over 1 year. I'm on my second 2.5r engine and I've run about 8 gallons through it in total.
I changed my brake disk for fun in June. The original one is still good.
Somethings not quite right if your melting the brake disc.
You can try a carbon fiber one, how long it lasts depends on how/why your melting the stock disc.
Old 08-12-2008, 05:47 PM   #5
gsxrmcs's Avatar
yea i am not really sure why it keeps melting but i do know that it is driving me nuts i am new to the RC world but with all the problems i am having with this it might just say the heck with it
Old 08-12-2008, 06:03 PM   #6
wes95_z28's Avatar
Sounds as if the idle is too high on the motor. Causing the brakes to work harder than normal to stop the truck.
Wes
Kyosho 777 WC w/ big bores, RB S5, ACE 1313 s., Air 357 t., JP-3
HPI Savage X SS, Axial .28, Hitec 5645 Steering servo
Nitro TC3, O.S. .18 CV-R
Associated RC18T, Brushless, Lipo
wes95_z28 is offline   Reply With Quote
Old 08-12-2008, 07:58 PM   #7
gsxrmcs's Avatar
i will try turning it down tomorrow and see if it helps
nitro brake pad question acsubie Electric Off-Road 0 08-04-2006 01:26 PM
Revo Brake Question mwcet8k Monster Trucks 3 06-01-2006 04:22 AM
ECS- Auto brake/Neutral Brake/Drag brake RC12L3a Electric On-Road 6 11-21-2004 09:10 PM
brake and sliding question dubwb Rookie Zone 7 09-05-2004 09:28 AM
Spedo & Drag Brake Question StewartFan20 Electric On-Road 0 07-19-2004 07:28 AM
