Old 08-12-2008, 04:32 PM   #16
David Day's Avatar
Send a message via AIM to David Day Send a message via MSN to David Day Send a message via Yahoo to David Day
Originally Posted by looneytune View Post
What's the best pipe for the P5XS? I'm going to buy another one, probably the turbo plug version. I have the Nova 9886 pipe now, but looking for suggestions for the new motor or should I get the same pipe again?
I recommend the JP-3 or OFNA 086
Anyone with a better one, please post it, I'd like to know as well
Day Brothers Racing
*http://daybrosracing.webege.com*
2nd Place 2006 Winter Series 10th/Scale Gas @ Lake Havasu RC Raceway
RC10GT - Snoopy #5x
Kyosho Inferno777 WC SP2
David Day is offline   Reply With Quote
Old 08-12-2008, 04:47 PM   #17
floss's Avatar
Trader Rating: 32 (100%+)
medium conical header with RS2031 for economy
REDS RACING ENGINES
Model Motorsports
floss is offline   Reply With Quote
Old 08-12-2008, 06:55 PM   #18
Poppin Fresh's Avatar
Houston, what's the Plus 821B? Newer version of the S821B? What did they change?
Poppin Fresh is offline   Reply With Quote
Old 08-12-2008, 08:18 PM   #19
houston's Avatar
Trader Rating: 91 (100%+)
i have to make them by putting an 821b p/s set in a plus 21-5k block and vuala !!! you got one badass engine .
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-12-2008, 10:15 PM   #20
maximugen's Avatar
Send a message via MSN to maximugen
what were the differences between the 821b and the 421b??
Mugen MBX5r - N/R 367 / Sirio bx STi
Mugen MST1 - JP RS12
Losi JRXSR- LRP SPX and Speed Passion 17.5R
HPI Savage - N/R 528
Trex 250
maximugen is offline   Reply With Quote
Old 08-13-2008, 04:25 PM   #21
houston's Avatar
porting on sleeve is pretty close to the same , crank on the 821 is drilled out to be lighter , 821 block has seperate diverters cast in the block for secondary rear intakes on the sleeve and new 25.8 mm rear bearing .
Old 08-13-2008, 07:36 PM   #22
Does that mean it has tons of bottom end for a truggy?
Old 08-13-2008, 10:58 PM   #23
maximugen's Avatar
421bx had larger rear bearing tho didnt it??
sorry shud have worded it better... 821b v 421bx . i loved my 421bx, it was an insane motor, so if the 821b is even more potent, i dont think there would be any hassles in a truggy
Trex 250
Old 08-14-2008, 10:32 PM   #24
houston's Avatar
plenty of everything
Old 08-15-2008, 04:05 PM   #25
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
I thought some S421B's had lightened filled cranks also. Does the 821B have a filled crank too?
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-15-2008, 07:10 PM   #26
houston's Avatar
Originally Posted by ezveedub View Post
I thought some S431B's had lightened filled cranks also. Does the 821B have a filled crank too?
no putty just drilled way through towards the front shaft , same as new updated p5xs engine .
Old 08-17-2008, 06:01 AM   #27
mremtr's Avatar
Every Novarossi (6 head bolt) version I have seen has a lightened and filled crank, the "other" 421 wanta be's like the Top and Rex had what ever was laying around I think. I have seen them with balanced cranks, stock(un modded) cranks and some with on-road style port openings and others that looked as if they were for a .12. Only consistant engines I have seen from Novarossi was the purple headed 6bolted 421's. AND I LOVE THEM !!!!
mremtr is offline   Reply With Quote
2 New Novarossi P5 Engines 1 Top + 1 Rex Sluggo R/C Items: For Sale/Trade 42 11-04-2005 09:16 PM
Novarossi or RB engines JaeGSX Nitro On-Road 3 01-04-2003 05:14 PM
Where to BUY Novarossi Engines warlord385 Nitro On-Road 5 12-23-2002 05:07 PM
