RB WS7II over heating >
Old 08-10-2008, 08:42 PM
smb17's Avatar
Trader Rating: 17 (100%+)
Exclamation RB WS7II over heating
How many shims are supposed to be on the WS7III standard plug?
I'm having trouble with my ws7III over heating i feel that im running it rich but it still pushes near 300. Any ideas?
smb17 is offline
Old 08-10-2008, 08:50 PM
spork01's Avatar
how many turns are the needles
spork01 is offline
Old 08-10-2008, 08:52 PM
If you are running 30% you are supposed to add one thin .1mm shim. You do not have to it will still run fine. Sounds like you leaned out your bottom way too much. Fatten the bottom maybe half a turn, or back to factory if you know what that was. Run it and get it really close with the top needle then just clean up the bottom. I never turned my low end needle more than 3 hours from factory.
katjim00 is offline
Old 08-10-2008, 09:16 PM
smb17's Avatar
i have 5 and 1/4 on the bottom and like 3 on top... its pretty close to factory.. I asked about shims because i added one and i got this engine used. so how many shims come stock on the engine..
smb17 is offline
Old 08-10-2008, 09:27 PM
It comes with 1 .2mm and 1 .1mm shim. You should be adding 1 .1mm shim for 30%.
If it is running 300 degrees it is not too rich. It is either too lean, or has an air leak.
What plug are you running?
largeorangefont is offline
Old 08-10-2008, 09:41 PM
smb17's Avatar
running an odonelle 99 plug losi 30% fuel.. i just added a .1mm shim before all this and its still hitting high temps... I know that its not too rich.. but i have it cranked up on the needles to where it wont run if i got any richer. i felt i had clutch problems but i dont know if that relates to it. just a lot of clutch slipping.
smb17 is offline
Old 08-10-2008, 10:19 PM
clutch problems absolutely relate to it, and are probably the root of your problem. Fix the clutch.
Old 08-10-2008, 10:58 PM
smb17's Avatar
well im not sure if i even have a clutch problem =]... but im picking up some shoes and just rebuilding anyways and probably seal up the carb.
smb17 is offline
Old 08-11-2008, 05:27 AM
vladconnery's Avatar
Trader Rating: 35 (100%+)
+1
I was having a problem with heat on my RB. i could not get it under control until I got the lsn set correctly. Place hsn back to factory maybe 2 hours rich and work the lsn until engine is running with temps in the normal range. Normal being about 200-220 closer to 200. Once you get the lsn set you can practicaly adjust the hsn needle and judge temp by the hour of turn. I can now literally turn my hsn and know what temp the engine is within 5 degrees. The other thing you may want consider is. You bought it used can that be the problem?
vladconnery is offline
Old 08-11-2008, 07:18 AM
one thing about that engine is it likes to run very rich my needles where always around fatcory only prob was could only get 7 mins max with the engine but it was good engien have it as a backup.
adz06 is offline
