Old 08-13-2008, 12:11 PM   #16
Zapped's Avatar
Trader Rating: 75 (100%+)
Send a message via Yahoo to Zapped
Originally Posted by Nitro syco View Post
I just got my first V-spec on monday and broke it in yesterday. But I was checking it out when I got it and noticed that the piston was in backwards! So that would definietly be something I would check because if they can put it together backwards on mine then they could have put it in backwards on yours too. Also mine came so rich it would barely start.
If that was the case, the piston skirt would have been damaged the first time it was turned over.
* B5M-FL * Tekno SCT410.3 * TLR 8ight-E 3.0 * TLR 8ight-T 3.0
Zapped is offline   Reply With Quote
Old 08-13-2008, 12:12 PM   #17
jpalessi's Avatar
Trader Rating: 55 (100%+)
Send a message via AIM to jpalessi Send a message via Skype™ to jpalessi
I would always check out ANY non modded engine, as these engines are mass produced, and thing like that happen. I would also inspect the carb for any factory defects, ripped o rings ect.... I have seen these mistakes happen before in V specs. I've seen pistons in backwards before,, also have seen broken pistons, brand new right out of the box.
Joe Alessi
www.Lucky7RC.com
jpalessi is offline   Reply With Quote
Old 08-13-2008, 12:13 PM   #18
jpalessi's Avatar
Wrong!
The engine will run with the piston in backward. Trust me!
Joe Alessi
www.Lucky7RC.com
Old 08-13-2008, 12:18 PM   #19
Zapped's Avatar
oops, My bad! I guess I'm used to Italian motors.
I would agree that it's always a good idea to make tear it down and make sure it's put together correctly.
Old 08-13-2008, 12:18 PM   #20
Jaz240's Avatar
Trader Rating: 52 (100%+)
Nothing is visibly broken, we have disassembled the engine 3 times! There are only 2 possibilities left.
1. Leaky front bearing.
2. Crankcase has a hairline crack, which is not visible to the naked eye, or to the spotlight, and magnifying glass!
I am going to do 1 final break down on Friday, and and I will let you all know what I find.
nothing to see here................................
Jaz240 is offline   Reply With Quote
Old 08-13-2008, 12:21 PM   #21
jpalessi's Avatar
it's ok... yeah most other engines it wont run... the spec has a long rod short stroke.
Joe Alessi
www.Lucky7RC.com
Old 08-13-2008, 12:25 PM   #22
jpalessi's Avatar
Is the engine wet after running it? Also try looking for the crack with a jeweler x10 eye piece. most of the time the cracks are straight down the center of the case on the raw material line. look there..
Joe Alessi
www.Lucky7RC.com
Old 08-13-2008, 12:53 PM   #23
Jaz240's Avatar
Ok, Thank you I will look there. Lets just say the case does have a crack. I have never encountered that problem before. How would I go about sealing that? Would silicone do it, or would I need to weld it closed? Please advise proper repair, that is one thing I have not ever done
Old 08-13-2008, 01:00 PM   #24
jpalessi's Avatar
There is no repair for a cracked case.... You'll have to buy a new case..
Is the engine wet after running?
Joe Alessi
www.Lucky7RC.com
Old 08-13-2008, 01:52 PM   #25
RBMike's Avatar
I've seen 3 OS V-specs with cracked cases in the past 3 or 4 months at my local club track where there are only about 50 members & way less than half of the members run v-specs.
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 08-13-2008, 02:20 PM   #26
Jaz240's Avatar
I don't remember wet or not, I will let you know later. I'm at work now, and did not bring my V-spec with me, lol
Old 08-13-2008, 03:04 PM   #27
mugenb46's Avatar
Jaz, i left you a post in the Best .21 engine thread, LMK
Brian Carey
Pro Twister Mods
brian@protwistermods.com
615-838-5373
mugenb46 is offline   Reply With Quote
Old 08-14-2008, 12:09 AM   #28
bgbelden's Avatar
One of my three blocks had a hairline crack, now i only have two.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
FS Harm SX3 07 Expert Edition kustom71 Australia For Sale/Trade 7 07-07-2008 02:12 AM
Need ICE CHARGER Expert?????? gunlocators Oval, Larger Scales and More 11 03-02-2007 05:53 AM
Vintage KO EX-1 expert vitor Singapore R/C Racers 6 01-12-2007 06:40 AM
expert soldering stephen hilton Electric On-Road 4 12-20-2006 11:11 AM
Need Expert Advice morpheous Malaysian R/C Racers 355 10-10-2003 02:24 AM
