Old 08-09-2008, 11:48 PM   #1
Trader Rating: 52 (98%+)
Default ned help fast ninja bo1a tuning
k my ninja has been running great for the first 2 1/2 galllons. problem has started. evrtime i give this gas it will not come back to idel it races for like 10 secounds or more. tried richening the low speed helps but still revs high and i went like five hours and did not improve. went lean on lsn and that made it worse. got it set to rev the lest and tryed hsn and that did not help either way i went. anyone have any clues as what this could b just started nitro this year know how to tune desent leanerd fast and tune lots of motors this thing got me stumpped. seal motor couple mounths ago so i dont think it has air leak but it may how do u test that new steal but learn fast use to race eltric and hang with nitro guys nie years ago so i know all the terms ans stuff just need some HELP anyone please. using number 6 plug jp3 pipe in losi 8t and byrons gen 2 11% oil 30% nitro
mixedguy is offline   Reply With Quote
Old 08-10-2008, 07:58 AM   #2
Integra's Avatar
you might be tuning for a High idle....ive seen it 10000 times at the track...take the filter off manually set the idle gap and try and retune....motor's do really strange things with a false high idle
Old 08-10-2008, 12:49 PM   #3
Kahuna77's Avatar
The original ninja's like a lean LSN and a rich HSN.
There a little tricky to find the tune, but once you do it will always be there with just small adjustments to the HSN.
One thing to is that they are not the best on the bottom, its a lot smother then most mills, once past this though they rip.
Hopefully your picken up what I'm layen down
Kahuna77 is offline   Reply With Quote
Old 08-10-2008, 06:32 PM   #4
Default idle gap
I check idle I thought it may have been that. gap is fine if I close it any more motor dies. can anyone think of anything else I am stumped
Old 08-10-2008, 07:23 PM   #5
scoopdaloop's Avatar
Trader Rating: 10 (92%+)
Send a message via AIM to scoopdaloop
Default Possible problems
So, the problem is when you hit the gas and then release the gas, the engine is still at a high rpm? 1. Servo check... make sure that it is bind/glitch free. Reset your endpoints also. 2. Fuel lines... replace them lol. 3. Air leak... start the engine and give it a spray of nitro cleaner and look for bubbles. Especially near the throttle boot. You already checked the idle, it kinda sounds like your servo or carb may be catching when it is sliding back into the carb...
scoopdaloop is offline   Reply With Quote
Old 08-10-2008, 08:58 PM   #6
check for sticky carb, I had 2 of those motors that did that.
katjim00 is offline   Reply With Quote
Old 08-11-2008, 11:27 AM   #7
Default thanks
k will check the carb and try new servo thanks for the help guys
Old 08-12-2008, 11:44 AM   #8
Default problem
i found the problem bad front bearing
Old 10-28-2008, 02:12 PM   #9
hairymuffin's Avatar
Trader Rating: 93 (100%+)
What plug is recommended for the BO1A? I have a cold plug in and it runs horrible. I am in always warm socal if that helps
hairymuffin is offline   Reply With Quote
Old 10-28-2008, 02:29 PM   #10
slaytanic's Avatar
Trader Rating: 20 (95%+)
Sounds exactly like an air leak. Guess you found it.
Team Epic
Team Terribles~Answer RC~Fastlane Graphics~Torco Race Fuels
XB808 Mamba Max Pro/Tekin 1900kv RC-monster mount and tray 4s
XT8 Hobbywing 150a esc/2000kv combo KILLER! Full rc-monster e conversion. 4s
slaytanic is offline   Reply With Quote
Old 10-28-2008, 11:45 PM   #11
I'm on my 3rd eng that starts out like that then tune got real un reliable then could barly get it around the track then the noise starts.At this time me & the 5 guys standing around that are stumped also all hear the noise & know exactly what it is. Scarrrry thing is full size auto mfg & dealerships have spent untold thousands on teaching me the exact chemical reactions that go on in a motor & what causes them & how to fix them & still I havent learned when to give up & put in a spare motor.
If you know how to tune & know what to look for & all the sudden cant get what you want in 2-3 tanks, give up its gonna do the same thing or worse 10 tanks from now. Go home & take it apart when you cool down.
I'll learn to listen to my gut some day,I hope.
butch man is offline   Reply With Quote
Old 10-29-2008, 02:58 AM   #12
allan42r's Avatar
if its the os ninja no.
the last ninja motor was made by grp.
if the bearings are gone my guess the motor's been run lean ALOT
Pinky kisses better than mason's mom
allan42r is offline   Reply With Quote
Ninja BO1A .21 engine and Ninja Pipe dzstr R/C Items: For Sale/Trade 3 12-15-2008 10:50 PM
Ninja bo1a and some rb stuff. jpz_67 R/C Items: For Sale/Trade 13 08-09-2008 11:20 AM
FS: Ninja MR21-BO1A paddyhong R/C Items: For Sale/Trade 2 07-17-2008 08:00 PM
xb8 ninja 21 bo1a Jim S R/C Items: For Sale/Trade 28 05-14-2008 08:21 PM
Ninja BO1A or V-spec. jpz_67 Nitro Off-Road 35 12-26-2007 02:11 PM
