Old 08-09-2008, 10:14 PM   #1
TC3ElectricGuy's Avatar
Default Newbee - Diff question
I bought a car 2nd hand which i was informed had all the diffs rebuilt 1 race before i purchased it.
however the centre diff is wet on the outside.. I'm sure this isn't normal, but is this a problem.
Should i rebuild this diff with new gaskets.
It doesn't appear to be dripping, just has a wet look to it.
thanks in advance
TC3ElectricGuy is offline   Reply With Quote
Old 08-10-2008, 12:30 AM   #2
if it were me i would go through and check just incase since its a used. that way u u eliminate the chance of melting a diff.
jstwin is offline   Reply With Quote
Old 08-10-2008, 09:40 AM   #3
Tree's Avatar
Send a message via ICQ to Tree
Whenever I buy a used rig, I completely strip the car down and inspect and rebuild anything that needs to be rebuilt. Then I put the car back together. I suggest that you do the same so that you can check everything on the car. You may find stuff that needs attention once you have it completely taken apart which you probably wouldn't have noticed if you hadn't stripped the car down. Good luck with your new rig.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Newbee - Please help identify my R/C's sambora68 Nitro Off-Road 0 08-11-2008 06:42 AM
Newbee at Buggy CIMRI Nitro Off-Road 13 07-13-2008 07:37 PM
Newbee yandain Rookie Zone 3 11-30-2006 05:34 PM
Newbee Question 3nero Chat Lounge 3 12-15-2004 09:25 AM
Newbee,,,,, Stanley Chong Malaysian R/C Racers 7 05-31-2003 03:42 PM
