Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 08-09-2008, 03:42 AM   #1
TTR:EB4's Avatar
Default Official O.S Engines thread
Hey this forum is for os engines, post how they are going, what have you done to them to make them go better etc, ive got a v-spec, 2gallons old, getting low on compression now for some reason, but she screams, its in my hyper 8.5, see pic, yer so post anything about these engines,
GREAT ENGINES
cheers
mike
The Masher! >.<
LOSI 8IGHT
O.S VZB V-SPEC
Hitec servos, Spektrum Controlled
Mainline Models Racing Team - www.mainlinemodels.net - MMRT
TTR:EB4 is offline   Reply With Quote
Old 08-09-2008, 04:13 AM   #2
I have an o.s speed 21 magnesium head.
So far its been a love/hate relationship. The engine screams but it doesnt have the much bottom end. I try to run the stock 16 clutch on my 808 but it kind of bogs on the bottom. And if i try to lean out the bottom it kind of stays on rev. I did change the main last week and it ran a little bit better.
Its funny because my friend has an 808 with 16 clutch bell and it seems to be running a little bit better.
I run with 1.0 kyosho springs now and i just tried 1.1, but i never liked it.
Hans_Andersson is offline   Reply With Quote
Old 08-09-2008, 04:24 AM   #3
MBR52's Avatar
Trader Rating: 7 (90%+)
Send a message via MSN to MBR52 Send a message via Yahoo to MBR52
Did ya fix your clutch problem mike?
Michael Brown
Associated RC8T - OS V-Spec - ACE Servos
Associated RC8B - OS Speed - Futaba Servos
Associated B44 - Novak Velociti 5.5 - JR Servo
Spektrum DX3R - AKA Tyres - Nitro-X Fuel
MBR52 is offline   Reply With Quote
Old 08-09-2008, 04:39 AM   #4
GREAT ENGINES
cheers
mike
2 gallons, it has a long life left!!
One older V-Spec with countless fuel ran through it , one 08 V-Spec with 2 gallons, one VG with about 6 gallons, and a Speed with a gallon. I like the 21J carb. All Ive done is rubber seal them at the carb base and pinch bolt. My Speed has killer bottom end, best engine by far.
MBX6
X2
O.S. SPEEDs
Hitecs
M11
DSM
and a Retired 8ight.
MonkeyWrench is offline   Reply With Quote
Old 08-09-2008, 04:52 AM   #5
Have you had to change the internals on many of these engines?
Rod, piston/sleve, bearings etc?
herb99 is offline   Reply With Quote
Old 08-09-2008, 05:08 AM   #6
lowey79's Avatar
I've had similar tuning issues with my speed. I read somewhere here that you can tune the bog out with the mid needle adjustment... Upto 1 turn in, in some cases!
It's meant to allow the engine clear faster off idle? I haven't tried it yet, but i'm keen to give it a try
lowey79 is offline   Reply With Quote
Old 08-09-2008, 05:26 AM   #7
ezveedub's Avatar
Trader Rating: 14 (100%+)
Send a message via AIM to ezveedub Send a message via Yahoo to ezveedub
If have a Speed with no bottom end, you have it tuned backwards. The engine is known for tons of bottom-end power. You need to lean the LSN and when it does high idle, start closing the idle screw on the carb. You will have to most likely richen the HSN, as it appears you compensating the LSN tune with the HSN needle. Mid screw has only been tuned between 2-4 o'clock position with screw flush with carb.
Also, they may move this thread. There is an engine discussion forum area already.
http://www.rctech.net/forum/exclusiv...ngine-zone-71/
Kyosho, Mugen Seiki, Maxy's Fuel, KO Propo
O.S., Ninja JX, Novarossi, RMV
ezveedub is offline   Reply With Quote
Old 08-09-2008, 07:45 AM   #8
UN4RACING's Avatar
I have a V-Spec and its the best darn engine I just cant begin to explain how great these are. I'm running the O.S. P3 plug and the JP2 pipe. best combo I have found for my liking.
I also have a O.S. ZX.28 That will light the tires up. I'm running it with the JP3 pipe and O.S. P3 plug. Talk about fast its a rocket but it has a fuel drinking problem.
I think they are the best buy, and they last. Also even if its a loose it will run.
Last night mine was the fastest of the pack in the straight. I tune mine between 230 and 250 run great.
No complaints with mine.
UN4RACING is offline   Reply With Quote
Old 08-09-2008, 08:20 AM   #9
bgbelden's Avatar
Sounds like your clutch is too big, try a 13-14 tooth. Unless your at a track with lonnnng straights you'll never get to use all your engine.
BATTLEFIELD RC
Team Terribles TN State Rep
bgbelden is offline   Reply With Quote
Old 08-09-2008, 08:25 AM   #10
bgbelden's Avatar
Yes i guess compression isn't thier strong suit but speed and durability are. I probably won't ru any other engine unless it's free or very cheap. These get great fuel mileage,and run very smooth.
BATTLEFIELD RC
Old 08-09-2008, 09:17 AM   #11
lowey79's Avatar
The internal gear ratio of the 808 is such that it run's a 16 tooth clutch bell as standard. If you run a 13-14 tooth C/B like on most other buggies, it will be severely under driven and have no top end.
yeh but that is a sub-forum of the nitro on-road forum. Why cant this thread be left in the nitro off-road forum where it's still relevant?
Old 08-09-2008, 10:01 AM   #12
greenracing's Avatar
have a OS Speed w 12 Gallons tru him..strong as an OX!!!!! i have this compulsion of changing rods after a break in, i do this in all the motors i have, that and the glow plug.. since then and 12 gallons of sidewinder fuel, no problems at all!!!
greenracing is offline   Reply With Quote
Old 08-09-2008, 11:47 AM   #13
Vsfriedmugan's Avatar
Send a message via MSN to Vsfriedmugan
yea! your clutch bell is way to BIG .... I run the racers edge 13t vented CB.. gives me monster low end!!!
MBX5R
O.S. V-SPEC (POWERHOUSE MODS)
O.S. SPEED
M11
JR
PROLINE
KING HEADZ
BYRON FUEL
Vsfriedmugan is offline   Reply With Quote
Old 08-09-2008, 01:46 PM   #14
Megacrash's Avatar
erm i hate to burst your bubble........
but the 16t is stock on the 808 due to its gearing same as with the rc8 which i run with a speed no issues at all
Mugen MBX6
Novarossi 367
Sanwa M11
Team Orion Servos
GAME ON!! - Team Terribles
Megacrash is offline   Reply With Quote
Old 08-09-2008, 03:23 PM   #15
Steve Walters's Avatar
Hans, if your OS Speed is bogging on the bottom, lean that LSN out! The OS Speed has the biggest bottom of any motor out there IMO. Every Big race I go to, I see more Semi & Pro drivers use a Speed "if" they don't have a Motor sponsor already. Its a power house!
"CVR" Central Valley Raceway (Madera, CA)
Team "WTF" Racing member
TEAM BCE (Product/Field Tester)
X-Ray 808 (Active Diff)
BCE 8X8 Pro Chassis
OS Speed (XCustoms Head Mod)
Hitec 5995TG (S&T)
M11 & Spectrum.
Steve Walters is offline   Reply With Quote
Forum Jump
Official Go-Tech Engines Thread MassiveMods Nitro Off-Road 9310 Today 06:22 PM
Official Go Engines Thread MassiveMods Australian Racing 1184 Today 02:46 PM
Maxy's Fuel and Maxy's Mod Engines (Official Thread) Tabushi Nitro Off-Road 93 10-26-2009 01:08 PM
** The Official HOT or NOT Thread *** JVT MTX3 Chat Lounge 2431 12-30-2007 04:19 PM
The Official xxx-nt thread rushdude Electric Off-Road 1 09-24-2003 03:09 PM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
