Old 08-09-2008, 09:45 AM   #16
Davidka's Avatar
Trader Rating: 75 (100%+)
I've run as little as 130oz on the steering with great results. If you think about it, 300oz will be overkill unless you lock down the servo saver. With a pretty tight servo saver setting I had no servo deflection on the bench with a Hitec 5625 (1310z/in). I use a 5945 because it's stronger and has a faster/coreless motor. Been using if for 3 seasons.
Old 08-09-2008, 09:54 AM   #17
rallyebmx's Avatar
Trader Rating: 21 (100%+)
Originally Posted by wstuart View Post
Ive heard 180 - 200 is the minimum for steering
I
I'd go with this.
rallyebmx is offline   Reply With Quote
Old 08-09-2008, 10:01 AM   #18
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Originally Posted by Krio View Post
The "T" is for Torque and the "S" is for Speed.
Thank you for all your replies, but maybe I should have rephrased it. How much torque is a recommended "minimum" for a competitive racer? I am looking at the futaba BLS452 which has 194 in/oz or the futaba BLS351 with 208 in/oz. Would these be sufficient?
Those will work I am using the very same 2 in my buggy. I'm running the 9000T and 9000s in my truggy.
UN4RACING is offline   Reply With Quote
Old 08-09-2008, 09:21 PM   #19
brofroe's Avatar
Trader Rating: 20 (100%+)
Originally Posted by cbaranski View Post
I'm going to use an Airtronics 94359 in my new RC8. It has 200 oz. of torque and .10 at 6v.
Chuck
thats what i just installed in my buggy. works great. turns the wheels as fast on the ground as it does on stand.
brofroe is offline   Reply With Quote
Old 08-10-2008, 05:13 AM   #20
I've ran servos with 130 oz with no problem at all. Not sure why you need 300 oz in the steering on a buggy. If you're at full lock on your radio and you try and turn your front tires and your servo saver moves before the servo then you've exceeded your maximum torque requirements. Any more won't help anything....
That being said right now I've got a JR 9100S and I love it. I tried the ACE 1015 but the .1 speed felt kinda slow in the quick direction changes, .06 makes the car feel way more responsive. YMMV.
psbarger is offline   Reply With Quote
Old 08-10-2008, 06:30 AM   #21
Suspended
Location: r.i.p Chiquita - 1993-2008 - "best dog in the world"
The reason someone suggested "As much torque as you can afford," which was very sound advice, is because between the weight of these buggies and the abuse they put the servos through either turning or landing jumps at speed it's worthwhile buying once than having to replace one often because you went with a cheaper/less torque model. Check out the torque rating on some of the namebrand servos that come in the RTR buggies and truggies, that people are always griping about having to replace, and go higher than that.
ratherBracin is offline   Reply With Quote
Old 08-10-2008, 08:34 AM   #22
jkas10's Avatar
Trader Rating: 121 (100%+)
Yes, either of these would be fine. I would go for the bls351 - great servo. I ran it in a buggy and now in truggy.
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 08-10-2008, 09:56 AM   #23
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I used to run the JR 8711 that have 300+ oz of torque. They are good servos but I think they are overkill. They are also slow, heavy and drain your battery quicker.
I know run either the 9100s or the ace's. The 9100s feel more connectected to the car because the are so much faster but the Ace's are probably tougher. Either one is great for steering on a buggy.
RC America - Team X-Ray - Maxys Fuel
infanterene is offline   Reply With Quote
Old 08-10-2008, 12:13 PM   #24
JustWill75's Avatar
Send a message via AIM to JustWill75
I've been wondering, is their such a thing as having to fast a steering servo for 1/8 buggy? I ask because I figure at some point too fast will make buggy to twichy? I am also looking for a good steering and throtle servo combination.
JustWill75 is offline   Reply With Quote
Old 08-10-2008, 02:41 PM   #25
viperbill1963's Avatar
Send a message via Yahoo to viperbill1963
Thumbs up jr servo
Originally Posted by 2005 crf 450 View Post
JR 9000T for steeting
JR 9000S for throttle
(you would think the T is for thottle and S for steering... or maybe im the one mixed up?)
the 9000T has 300+ oz of torque
the 9000S reacting time is like .06 seconds at 6V
cant ask for anything better, and JR has the best warranty out there, 3 years hassle free.
t= torque not throttle
s=speed not steering
team associated RC8.2E tekin esc and motor jr z9100s servo spektrum rx
X-FACTORY X-6 square tekin esc lrp motor spektrum rx soon to be a cube
viperbill1963 is offline   Reply With Quote
WTB Steering servo high speed / good torque slufoot78 R/C Items: Wanted to Buy 6 05-23-2007 12:42 AM
>>>>> HITEC 985MG Steering Servo Hi-Torque for Truggies and Monster Trucks and More < mach51 R/C Items: For Sale/Trade 4 02-08-2007 07:10 PM
looking for a m8 and high torque steering servo rhymster R/C Items: Wanted to Buy 5 08-14-2006 07:33 AM
Acceptable servo speed and torque?(steering) 2000xp8 Electric On-Road 21 01-31-2005 03:09 AM
Minimum torque for 1/8 competition steering servo FREAKAH Electric Off-Road 14 09-07-2004 03:07 PM
