Old 08-08-2008, 04:21 PM   #16
Jimmy Jacobson's Avatar
Proline medium is best
Jimmy Jacobson is offline   Reply With Quote
Old 08-08-2008, 06:31 PM   #17
moeman's Avatar
Trader Rating: 26 (100%+)
I use Sexpanther glue...60 percent of time, it works everytime.
moeman is offline   Reply With Quote
Old 08-08-2008, 06:37 PM   #18
rc31cli's Avatar
Default ok
just use zap the glue comes in a clear bottle with a pink lable and is chaep and i have never had a 1/8th scale tire come unglued.
My 2012 sponsers thanks guys!
smokin hot fiance, battlefield rc, jconcepts, competition heat, werks racing, dalton rc, murnan modified motors, and airtronics
driver: Coty Ingram
rc31cli is offline   Reply With Quote
Old 08-08-2008, 06:57 PM   #19
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Losi or Trinity .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-08-2008, 07:19 PM   #20
romeo_charlie33's Avatar
Default Tire glue
ZAP works well so does any super glue from your local $1 store. Just use some 400grit sandpaper and scuff the bead on the rim and clean both the rim and tire with acetone or other cleaner that wont leave a film when dry anywhere where glue is to be placed. I have not had any tires come off since doing it this way. Also use tire bands, rubber bands or eletrical tape to hold the tire to the rim with pressure while drying and run a bead of glue arround edge to help seal it from dirt and rolling over.
romeo_charlie33 is offline   Reply With Quote
Old 08-08-2008, 07:34 PM   #21
Jesse Robbers's Avatar
Send a message via AIM to Jesse Robbers
The Losi glue is good, if you're lucky to not get bad bottles which happens with it. I have not used PL glue, now I use Loctite from Home Depot (in same bottle as PL and TL glue). I think the loctite works as good or better, haven't had any bad loctite glue yet, and it's cheaper. Lostite = $6 where TL is $8 and PL is $9 a bottle.
Sponsored by: O.S. Speed, KO Propo, Sidewinder, Tekin, Thunder Power, Lunsford, Skipgear.com, Fioroni, Avid R/C, GMK Supply, Competition Heat, Dialed Inc., LiveRC.com, DE Racing, CIG2O, ANDROID Nitro Runtime Calculator App
Jesse Robbers is offline   Reply With Quote
Old 08-08-2008, 07:39 PM   #22
pink_sleeve's Avatar
Trader Rating: 163 (99%+)
Jesse what is the number on the Loctite?
pink_sleeve is offline   Reply With Quote
Old 08-08-2008, 08:12 PM   #23
fishin4cars's Avatar
Good info! Most all the glues work well if you use the above method. I like Losi due to the applicator tube also. Once I started using the above mthod i have yet to have a tire come loose off of the rim. Now I just have to figure out how to keep from popping the foams inside the tire. I've had three split and seperate and all you can do by that point is trash them.
fishin4cars is offline   Reply With Quote
Old 08-08-2008, 09:03 PM   #24
Suspended
Location: r.i.p Chiquita - 1993-2008 - "best dog in the world"
Originally Posted by OTE_TheMissile View Post
I just use regular Loctite brand cyanoacrylate glue from the hardware store.
Loctite for sure ---- and I get the type with the little brush in the bottle, that way it allows you to use just how much you want and put it were you want. Clean application, no spills, no drips, no errors, no muss, no fuss.
ratherBracin is offline   Reply With Quote
Old 08-09-2008, 09:14 PM   #25
What is the dry time like on loctite?
My biggest troubles come from the glue setting too quickly. Using CA, the bond is good, however it likes to grab a part of the tire before I get it just where I want it. Normally I put the tire on, use electrical tape to apply some pressure, then simply peel up the bead a bit and put glue in it. However, sometimes the bead doesn't want to seat well instantly, and if it doesn't I find it is stuck where it lays. It would be nice if there was a glue that you could apply liberally, get the tire seated well, then just let it dry for 8-10 hours.
The other problem I have with CA is it tends to dry and leave a white residue on the wheels. Not a problem except I like to use black rims Does loctite fix any of these issues?
Larks is offline   Reply With Quote
Old 08-10-2008, 05:44 AM   #26
Suspended
If you take some acetone, and wipe them down afterwards, it'll usually remove any of the white residue.
Old 08-10-2008, 09:44 AM   #27
Tree's Avatar
Send a message via ICQ to Tree
I also use Zap glue but the green lable one. Strong and inexpensive. I have yet to have a set of tires come off of the wheels. But I do prep them before gluing. I scuff the wheel and tire bead with 150 grit sandpaper then I clean the rim and tire with denatured alcohol or nitro cleaner. then glue them up.
Team Holy Rollers
HiTec Servos
"N-Tune" Nitro Engine Tuning Dials
Tree is offline   Reply With Quote
Old 08-10-2008, 10:25 AM   #28
Trader Rating: 18 (100%+)
Send a message via Yahoo to infanterene
I used to use proline but got a few bad bottles. Now I am using Jet medium. It comes in a 2oz bottle that cost $9.
Lately I have been using GRP tires and with absolutly zero prep they are staying together just fine. I think that with Proline tires I would atleast have to wipe of the mold release.
RC America - Team X-Ray - Maxys Fuel
infanterene is offline   Reply With Quote
Old 08-10-2008, 10:31 AM   #29
mremtr's Avatar
I prep every tire before gluing them ,even re-prep ones I have dis-mounted by using my dremel with a sanding drum in it and go around the beads tom make them blem free , panther,proline,grp I do them all this way and use the thin stuff, what ever brand I can get that is fresh !I have never lost a tire doing it this way!
mremtr is offline   Reply With Quote
Old 08-10-2008, 12:14 PM   #30
porkchop's Avatar
Send a message via AIM to porkchop Send a message via Yahoo to porkchop
koysho glue kept in the bag
charles garten
serpent / novarossi / Desoto Racing / Absolute Hobbyz / ko propo / first turn racing usa / KustomRcGraphics / O'donnell racing fuel / Houstons Engine Service / sweep racing tires
porkchop is offline   Reply With Quote
Tire glue? lowey79 Nitro Off-Road 17 09-11-2008 04:23 AM
tire glue HELP jedsled Electric Off-Road 9 04-16-2008 05:27 AM
Best tire glue LogiK Nitro Off-Road 28 04-12-2008 09:09 PM
TIRE GLUE pink_sleeve Electric Off-Road 27 11-29-2007 06:42 AM
trc #902 tire Glue WTB rcfoolz R/C Items: Wanted to Buy 0 12-11-2006 03:47 AM
