Old 08-06-2008, 04:59 PM   #1
Greenlee37's Avatar
Trader Rating: 32 (100%+)
Default KYOSHO ST-RR set-ups and tips
Quick question...? Off the setup sheet Im using, for the rear hubs, it says "Rear Hub Hingepin Position" with boxes to check "upper" and "lower"... The box UPPER is marked with an X....... this might seem like a dumb question, but at frst glance I thought this means install hub in upper position which means I would have to use the lower hole to insert the hinge pin... but then reading it again, I thought wait, maybe that means slide the hingepin in the upper hole???????? I hope I explained this correctly... Guess an easier way to ask the question is..... if the box is checked for "UPPER", which hole do you use for the ihngepin on the rear hub...... I must be having a brain fart.... but thougt Id ask on here see if I can get a quick answer........
THANKS
Greenlee37 is offline   Reply With Quote
Old 08-06-2008, 05:39 PM   #2
That means use the uper hole, so the hub will sit lower down.
Nitro syco is offline   Reply With Quote
Old 08-06-2008, 05:41 PM   #3
Greenlee37's Avatar
hey thanks... thats what I thought... appreciate your feedback
Old 08-27-2008, 01:59 AM   #4
pitpop's Avatar
the upside down car guy is right
Cody King's Wrench (and dad :))| Team Kyosho International | Reds Racing Engines | Pro-Line Tires
KO Propo | Byron Fuels | AbsoluteHobbyz.com | Stickit1 Racing | kustomrcgraphics.com
LiveRC.com | OCRC Raceway | codykingrc.com | ROAR Sanctioning Director
pitpop is offline   Reply With Quote
KYOSHO STR/TIPS/PICS/VIDEO'S/TOPICS/EXC.. in2deep Nitro Off-Road 72 06-27-2008 05:39 AM
Any tips for the Kyosho SIII kyosho cup addition Bad Inferno Australian Racing 2 06-26-2008 11:28 AM
Tips. Infamouz Nitro On-Road 1 02-09-2007 05:13 PM
Tips on TC3 Kit Richy89 Electric On-Road 6 03-03-2004 02:52 PM
Kyosho MP6 Maintenance tips jvannghi Electric Off-Road 2 01-12-2003 05:44 AM
