Old 08-06-2008, 11:08 AM   #1
Default Clutch Bell Bearing Issue
I have been racing for 7 months now and have not had a problem with my clutch bell bearings until a couple of races ago. It seems as soon as I put new ones in and run one lap, the front bearing lets go and the bearing moves up and starts rubbing the fuel tank (I have a Losi 8ight btw). I have checked the mesh and have swapped clutch bells for a new one. The clutch bell spins freely and only has the slightest bit of play. If I add another spacer then it is tight enough to cause concern that the tightness could be the cause of the problem. I am using Protec bearings and have been told that these are terrible bearings. I started with Losi and had no problems with the Losi ones but have only had bad problems with the Protec ones since switching. Is this really the answer to my problem is the brand of bearings? Please help! Thanks!
843rcguy is offline   Reply With Quote
Old 08-06-2008, 11:14 AM   #2
Crim3Wav3's Avatar
is the crankshaft worn where the bearings sit? If there is enough slop, they could be heating up too much (actually spinning on the crankshaft) causing premature failure.....check it out.
Crim3Wav3 is offline   Reply With Quote
Old 08-06-2008, 11:33 AM   #3
Is your crankshaft clean where the bearings sit? You may need to clean off those little rust areas where the bearings sit with some fine sandpaper. If there is enough rust on there the bearings wont last very long. Another thing is if your gear mesh between the cluth bell and spur gear is to tight then when the chassis flexes it puts way to much stress on the bearings so they wont last very long that way either, and the chassis will flex every time you land a jump or hit a rut or whatever, so that can be a problem.
Nitro syco is offline   Reply With Quote
Old 08-06-2008, 11:43 AM   #4
DOMIT's Avatar
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
Send a message via MSN to DOMIT Send a message via Yahoo to DOMIT
Well... it could be any of the things mentioned. Chassis flex is particularly pronounced on the Losi in that area... so normally Losi drivers run a looser mesh than others. Also the King Headz extended motor mount helps...
Brad "DOMIT" Smith - I'm not fast, but at least I wreck a lot.
Unsponsored, but I use/recommend: XRay XB9, Alpha A852, Dynamite 053, Airtronics M11, Hitec 5955TG & 7955TG, ABEC 35 clutch and chassis bearings, PTRCRacing shock and diff fluids, Ready Rollers ceramic engine bearings. ** Team Terribles Region 9 coordinator. ** JOIN TEAM TERRIBLES! All racers welcome! PM me for details.
DOMIT is offline   Reply With Quote
Old 08-06-2008, 11:44 AM   #5
Trader Rating: 36 (100%+)
Try removing one shim, if possible. I've read in forums past, somewhere, that the 8 clutch ( assuming your running the stock system? ) likes to be a little more loose than a regular 3 shoe style.
NitroOB4You is offline   Reply With Quote
Old 08-06-2008, 07:58 PM   #6
Trader Rating: 27 (100%+)
Did you use the same engine those 7 months? If so the crank bearings could be worn and cause the clutch bearings to blow. My buddy had that happen before and man did it frustrate him to no end until he figured it out.
Team Associated & CRC
Trackstar & Hobbywing esc's
Spektrum radios, GensAce batts, turnigy servos.
Keeping racing fun and affordable with my 8y.o. twins :)
The best track I've raced is the one in my backyard!
jbrow1 is offline   Reply With Quote
Old 08-06-2008, 08:28 PM   #7
Run a Looser Mesh and run Avid Revolutions. There a buck a pop.
MonkeyWrench is offline   Reply With Quote
Old 08-06-2008, 08:38 PM   #8
looneytune's Avatar
Trader Rating: 23 (100%+)
I run a looser mesh, more than average end play, and the King Headz extended mount on my Losi and no issues with bearings at all.
looneytune is offline   Reply With Quote
Old 08-06-2008, 09:08 PM   #9
jrwoodchuck's Avatar
I use the pro-tek ones. A buck each and I replace the inside one after every weekend, outside one every other. No issues..
Doug
TLR 22/M-11
“Looks like I picked the wrong week to quit sniffing glue.”
jrwoodchuck is offline   Reply With Quote
Old 08-07-2008, 04:02 AM   #10
vladconnery's Avatar
Trader Rating: 35 (100%+)
I was told when I got my Losi to mesh with a folded piece of paper between CB and spur. I did it and it seemed way to sloppy I ran it that way with no problems. I had taken my buggy apart for a cleaning and remeshed by sight and sound. Burned up CB bearings in less than a day of use. Replaced bearings and remeshed with folded paper bearings still going strong. original mesh I got 2 gallons on bearings. After my mesh less than 5 tanks. After remesh a gallon and still going. Losi's like it sloppy.
KO PROPO EURUS
Kyosho: TKI3, TKIe Tekin RX8 Gen2
vladconnery is offline   Reply With Quote
Old 08-07-2008, 08:47 AM   #11
Thanks guys. I replaced the motor before I started having the bearing issues. Brand new V-spec. I will try all of the above to see if the problem gets better. I think I have it too tight as far as the mesh as I have done it by feel and by previous experience with other vehicles and not necessarily the Losi. At first, it was done by paper and then by feel.
Old 08-07-2008, 09:47 AM   #12
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i run the yellow seal boca cb bearings.. i have had good luck with them so far.. but i dont give them a chance to wear out because i replace them before every big race and every other weekend of club racing.
jamminnay is offline   Reply With Quote
Old 08-08-2008, 01:51 AM   #13
It could be the flywheel nut. Make sure it's very tight. I had a similar issue once and found the bloody thing loose after destroying 3 pairs of clutch bearings in a day.
Kev Lewis,
I'd like to thank my personal Sponsors :-AKA Tyres Australia, Ryper Hobbies and Just Hobbies
The Gear :- Associated RC8 B3 powered by OS Engines
Soapy is offline   Reply With Quote
Old 08-21-2008, 05:23 PM   #14
I tried remeshing a little looser and got a day out of the front bearing. Luckily the front one made it until the end of the 30 min A main and I was able to take second. The folded piece of paper though, was it notebook or copy paper? I am remeshing it for another race coming up and need to get it right. When I first got it with the first motor, one of the fellow racers meshed it for me. Then I got the CEO V-Spec and I am pretty sure I have it too tight.
Old 08-21-2008, 05:55 PM   #15
DOMIT's Avatar
The Losi has to be set up "you gotta be kidding me" sloppy on clutch mesh.
What can cause excessive clutch bell bearing failures? MattP Nitro Off-Road 13 04-29-2008 07:06 PM
Clutch bell bearing problems rltanner Nitro Off-Road 14 02-20-2008 12:52 PM
Removing a stuck thrust bearing from the clutch bell Darthswan Nitro On-Road 0 08-01-2005 10:13 AM
WANTED:Savage parts-clutch bell, clutch shoes, rear driveshaft,etc..Orlando, Fl. 10gter Florida Racing 0 01-26-2004 08:54 AM
kfactory ntc3 30mm push clutch bell to mugen centax clutch set mugen_kid Nitro On-Road 1 03-04-2003 04:01 PM
